has anyone done it??? does it make much difference???
dynamat????
is it worth using when mounting the front speakers, my understandaing is that you put it around the speaker holes in the front and mount the speaker to it
secondtimelucky
Basically yes but you should also line the enclosure of the speaker as well. its designed to stop the speaker rattling and the enclosure from resonating (creating unwanted noises/harmonics)
Wanted: Any old component speakers, complete or separate parts, let me know what you got
would it make any differnce with some mid drivers in the footwell ????
secondtimelucky
Yeah bud it would. It would sound more detailed in the mid/bass, more full in the lower bass and generally alot cleaner and focused throughout the range. For example. if you imagine even on a cheap set of home speakers, how thick the enclosure is for rigidity. Then compare it to the relative tinfoil that makes up the e30 enclosure... You will see where much of the sound quality is lost, moving the enclosure intead of the cone. Dynamat will minimise the effects of that. lol
. IIRC if you were to totally dynamat your car (yes i know how expensive it can be) you would gain up to 10db of volume at a given power level
yer they do sound better enclosed, is there any way of enclosing them behind easily,
secondtimelucky
They already have enclosures, just crap tiny ones made of thin metal, dynamting will seal the enclosures up and reduce vibrations/distortion.Im not sure if its the drivers or passengers side or both
but one of them has the wiring loom running through it which i sealed with silicone sealant or similar. basically you need to make the enclosures as airtight as possible with dynamat lining the inner surfaces
so dynomat goes on the front where the speaker goes or inside or both
is there anyway of dynomatting the rear???
or is it a problem with them being mounted to the parcel shelf
secondtimelucky
Mainly inside, on all the sufaces you can get to inside the enclosures. You may gain a small improvement by putting a layer of 'mat' between the speaker and its mounting, but i doubt you would notice it really
I take it this for the IS? If so the rear speakers are known as 'free air' speakers meaning they have no real enclosure but use the bootspace instead. The only benefit from 'd-mat' would be to do the whole metal parcel shelf surface under the trim/cover thing HTH
Last edited by secondtimelucky on Thu Nov 13, 2008 4:57 pm, edited 1 time in total.
secondtimelucky
So i guess your gonna go for it then?? you'l be surprised by the difference in the bass and mid quality you get
cliffybabe
- Powered by Nelly
yes dynamate or brown bread well worth it
will kingsmill best of both work fine
cliffybabe
- Powered by Nelly
ah rite
cliffybabe
- Powered by Nelly
secondtimelucky
lol, you muppet Alex
did you think i thought it was bread likesecondtimelucky wrote:lol, you muppet Alex
secondtimelucky
sati
do you know its take 2 times the power to gain 3db , it will take over 3 times of power to get a 10db gain. matting can give a gain up to 3db's. no were near 10db. , if 10db gain only costs £60 (wholesale) then i can can just put loads of layers down and get a big gain, which is not true.
secondtimelucky
sati wrote:do you know its take 2 times the power to gain 3db , it will take over 3 times of power to get a 10db gain. matting can give a gain up to 3db's. no were near 10db. , if 10db gain only costs £60 (wholesale) then i can can just put loads of layers down and get a big gain, which is not true.
You are quite right sati
