2.8 build
Post Sun Apr 13, 2008 5:55 pm
Glad to hear it!!! Now get out there n get the bugger run in! :wink: :cool:
JazzMan
Post Sun Apr 13, 2008 7:12 pm
If the weather were better I'd run it into work as I do about 50 miles a day - would have it run in pretty quick!
Forgot to say did a compression test as well all within a smidgen of 12bar over all 6 cylinders.
Andy325i
Post Mon Apr 14, 2008 9:10 am
Excellent! :) Glad its back running again :)
JazzMan
Post Mon Sep 29, 2008 6:03 pm
Good news it passed the MOT emissions test no problems at all today :cool:
**BANNED**
Post Mon Sep 29, 2008 6:12 pm
JazzMan wrote:Good news it passed the MOT emissions test no problems at all today :cool:
Ahh,but what happened when you started the engine? winkeye only kidding..well done :D
Andyboy
Alpina Colada
Post Mon Sep 29, 2008 8:46 pm
I have a 2.8 M52 crank and six 130mm rods if anyone wants to do the same. £175 to you. :D
JazzMan
Post Tue Sep 30, 2008 12:36 pm
:lol: I wasn't there with it (no weekend test slots until the middle of next month so my dad took it there for me :) ) so I don't know the exact results. He said they shoved it up the back end and said it was fine which is OK by me :cool:
Rik178m
Post Tue Oct 28, 2008 9:03 pm
Have you had it rolling roaded yet mate?
JazzMan
Post Tue Oct 28, 2008 9:56 pm
Rik178m wrote:Have you had it rolling roaded yet mate?
Not yet, there was a RR day that never materialised on another forum a while back. I think the engine's probably run in enough now to get it metered. Would be interesting to see how it does with a generic map considering the modifications.
Ideally I'd like to get it custom mapped or get standalone management with a RR map, need to get it painted first though :)
hennie
Post Wed Nov 26, 2008 9:48 pm
here is a thread to my 2.8 stroker with dyno sheet
you need to register to read the post
http://www.e30clubsa.co.za/forum/index. ... topic=3350
Gunni
Post Wed Nov 26, 2008 10:24 pm
can´t you just quote the important bits into this thread?
With great challenges comes great engineering.
Gunni
@ 2012 VEMS group buy !!
hennie
Post Thu Nov 27, 2008 7:18 am
i used a 525 e block, e 36 2.8 crank, 130mm con rods, 9.4 compression ratio 325 i pistons and 325 head gas flowed, running a 280 cam and tnt branches and free flow compression ratio in motor is 10.5
re chipped ecu for the South African 2.7 evo 2 (or IS as its called here )
revlimit 7500 rpm and 325 injectors with a 3.2 bar feull presure regulator
plus a smt6 piggyback and maf conversion used the z 3 maf also running a 320 flywheel car has done 30000km since the conversion and is still going strong
Image[/img]
the dyno is the before smt6 and maf conversion with a 535 modified afm
the after is with the smt 6 and maf conversion i
the kw figure translates to about 207 hp
