E30 to M30 brake vacuum connection
winx
Post Tue Oct 14, 2008 6:52 pm
Has anyone got any pictures or advice on how they linked the e30 brake servo to the inlet manifold? On my 320i there are are 2 pipes going into the inlet manilfod, can I just blank one of these off and put the other into the m30 inlet manifold?
DRIFTBOY
Post Tue Oct 14, 2008 7:15 pm
You've half answered your question there, and correctly.
I've only got this photo at the moment, but it is very simple.
I used the E30 plastic 90 degree plug thing that goes in the servo, some of any of the spare hose you've already got and cut to a suitable length and the M30 one way valve thing.
If the valve has a small stub coming off it with a tiny hole in the end then that needs to be blanked off.
Some have the little second pipe and some don't, It's for some feature of certain E32s and E34s I think.
winx
Post Tue Oct 14, 2008 7:19 pm
Nice thanks for that, havent got the M30 one way valve so phone call to the dealers tomorrow or see if I can seal one end of the E30 twin return valve!
Ta!
Post Fri Oct 17, 2008 9:11 am
90% of cars of all makes in a scrapyard will have a suitable one way valve, as well as M40 engined E30s and late M20s.
winx
Post Fri Oct 17, 2008 10:39 am
Thanks Brian, will have a rummage next time I am near a scrappies.
