Hockey puck engine mounts. Postage on P3
Enter a group buy or look here for zone discounts
ric325i
Post Wed Aug 20, 2008 4:29 pm
who is getting hocky pucks for the gearbox then????
sounds like the plan if you lower the engine.
im happy where my m30 lump is (as i dont have much choice with the big lump) but i will have a good look at the alignment and see if the gear box mounts need lowering from your advice. those centre bearing arnt cheap.
UweM3
Post Sun Aug 24, 2008 3:49 pm
well, I spend the day yesterday on the milling machine to fabricate some ice hockey gear box mounts.
To cut a long story short, I will take the off the car ASAP! The noise is just unbearable!!!
fitted
oze30
Post Sun Aug 24, 2008 6:39 pm
Interesting.
Dave_M3
Post Fri Aug 29, 2008 10:07 pm
I've not been on the zone for a week or so Oze, so sorry f you've had no word from me.
Raising the engine and box would be all well and good, but the prop has no knuckle between the gearbox and the center bearing, If it did we could put the engine where we want.
Machining the pucks isn't a big deal anyway, just have to get the compressed height of the OE mounts and a few minutes on the lathe will have them done :)
I could see why the pucks on the gearbox would give so much vibration alright when the box is bolted on to the body right beside your feet, lol.
oze30
Post Wed Sep 17, 2008 10:23 am
Bumpage
Dave_M3
Post Fri Sep 19, 2008 5:31 pm
So when we taking final orders of these or is it as soon as we get 25 people? :)
Theo
Post Fri Sep 19, 2008 5:48 pm
Colin could you bring a couple of pucks to santa pod please?
oze30
Post Fri Sep 19, 2008 6:08 pm
define a couple???
Theo
Post Fri Sep 19, 2008 6:36 pm
2
I might only need one though!
oze30
Post Sat Sep 20, 2008 10:52 am
Don't know if I'm going to the pod. No car to show off. BUT i'm on the way.
Theo
Post Sat Sep 20, 2008 11:37 am
That's a shame, forgot that the touring is off the road - would have been good to see what time it was capable of down the strip.
I'll just get a puck or two from a sports shop I think, not worth the hassle of taking a detour to be honest. If you do come, bring a couple along please.
oze30
Post Sat Sep 20, 2008 5:51 pm
Theo325 wrote:That's a shame, forgot that the touring is off the road - would have been good to see what time it was capable of down the strip.
more than welcome to get them from a shop.. At £3.00 each roughly.. your choice.
DawieM3
Post Sat Sep 20, 2008 6:14 pm
If using the pucks on a road car will be a good idea to strengthen the sub frame mounting points. ( Usually prone to cracking ). The engine is more solidly mounted so the subframe takes more of a hamering. The pucks will also improve your car`s handling as you don`t have the heavy lump moving around as it use to.
Uwe has a kit for this, and is well worth doing. Just remember not to overtighten the centre bolt or heavy vibration will result. I have used mine for some 5 years now on an E30 m3 which been heavily tracked and have only suffered one rubber coupling failure and that was down to the gearbox output flange breaking.
It is a practicle, cheap worthwhile mod, and if you don`t like it you simply bolt in something else.
I would think this would also be a good mod for a drift car.
Have fun,
E30 M3 Track car S14, 2.5l
2002, 2.0l fuel injected
E30 C2 2.7 Alpina
E36 M3 Evo
1602, - 2.5 S14
2002 E10 -M57 on e46 floorpan
335d - e92
320d -e92
Jag xj8 4.0l
Mitsu L200 animal
Taylor325i
Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Post Mon Oct 06, 2008 10:28 pm
These still available? If so, I'll take 4 pucks please. :thumb:
Taylor.
Theo
Post Thu Oct 09, 2008 11:13 am
Colin do you still have any of these? Couldn't get some from my local shop in the end.
I need two, can you post them to me?
Cheers,
Theo
oze30
Post Thu Oct 09, 2008 9:08 pm
Can do. Pm me your details
oze30
Post Fri Oct 10, 2008 4:56 pm
Oops
Double post!
oze30
Post Fri Oct 10, 2008 4:57 pm
Postage update:
Just got back from the postoffice.
2 pucks = 3.00
postage= 2.50
total = 5.50
4 pucks = 6.00
postage = 3.00 (with 4 washers = 3.50)
total = 9.00 (washers 9.50)
6 pucks = 9.00
postage = 5.00
total = 14.00
Of course this is to mainland UK or wherever royal snail do their mainland delivery to.
Dave_M3
Post Thu Oct 16, 2008 4:58 pm
4 pucks 6 quid
6 pucks 9 quid
12 pucks 12 quid
Is this just for the pucks or the pucks and washers?
There is one or two more people thinking about getting them over here now so as soon as I have them all definite I'll tell them to get in touch about paying you and we'll send them all over together.
I'm getting my own lathe in a few days so they will give me something to do on it winkeye
Theo
Post Fri Oct 17, 2008 11:18 am
Have my pucks been posted yet?
oze30
Post Fri Oct 17, 2008 3:55 pm
posted today. Sorry been flat out with work.
oze30
Post Fri Oct 17, 2008 3:56 pm
Dave_M3 wrote:4 pucks 6 quid
6 pucks 9 quid
12 pucks 12 quid
Postage update:
2 pucks = 3.00
postage= 2.50
total = 5.50
4 pucks = 6.00
6 pucks = 9.00
postage = 5.00
total = 14.00
rob0r
Post Thu Nov 13, 2008 3:04 pm
Received my pucks, many thanks.
oze30
Post Fri Nov 14, 2008 9:12 am
No probs. :D
oze30
Post Sun Nov 23, 2008 9:01 pm
Anyone??
Dresden
Post Fri Dec 05, 2008 3:11 am
I work at a hardware store (going to college in America) and one thing you could try is to "tap" the pucks. A tap basically threads a hole to put a bolt in. After that you could use some neoprene washers and "thread lock" to keep it tight and silent.
oze30
Post Fri Dec 05, 2008 8:58 am
Dresden wrote:I work at a hardware store (going to college in America) and one thing you could try is to "tap" the pucks. A tap basically threads a hole to put a bolt in. After that you could use some neoprene washers and "thread lock" to keep it tight and silent.
Not sure if tapping it would be a good idea I wouldn't have thought the rubber would be strong enough.
oze30
Post Wed Feb 25, 2009 10:14 pm
Bumpage
Rallyprep_UK
formerly Driftnething
Post Thu Jul 30, 2009 8:53 pm
hey there,
Can I have 12 please !
thanks ;)
Will
Rallyprep_UK
Post Tue Aug 04, 2009 10:38 pm
pleeeeeeeeeeeeeeeeeeeeeeeease !!!
oze30
Post Sat Aug 08, 2009 1:37 pm
pm Spadge as he can get them out to you.
Rallyprep_UK
Post Sat Aug 22, 2009 4:35 pm
cool thanks :D
