getting close now...
- Le Surrender Monkey.
- Location: guernsey.... i mean france munching on garlic and drinking wine with my children.
haha the 440cc ones wont give me enough fuel for what i want!lol
the only thing im worried about is bedding the rings in mate, need to get it out!!lol
Ixer said I can have 1.4 bar on mine, that'll do!rossle wrote:haha the 440cc ones wont give me enough fuel for what i want!lol
Sod bedding them in, stock bottom ends does me for now!
Off home, catch you later, I'll be on msnm later hopefully, mrs is out getting pi55ed so I can play all night! LOL
Take care. Fozz.
fozz are you still using the standard viscous fan?
turned on the heaters wile the car was running and the air was still cold...
you have probably put the hoses on wrong into the HVAC.
post up a log of your tuning and msq.
I´ll sort you out fuel wize ;)
cheers gunni, just need it drivable, better to be on the rich side too.
how do i post up a log then?
pm sent already
Yes, stock fan here.rossle wrote:fozz are you still using the standard viscous fan?
def air locked, that's the usual issue, it might be worth filling the matrix through the pipes in the bulkhead.
massage them all till the coolant stops bubbling through the bleed valve.
@ Gunnii, do you have a typical afr arget map? I've set mine but not 100% it's right.
Fozz
yeah, thought it might be air locked, gonna try sort it tomorrow, and get the log and map for gunni as he has very nicley said he would sort the fuel!!
what a nice chap!!
what a nice chap!!
I´ve seen it a million times, it´s the hose pipes on the wrong way ;)
Fozz what does your lambda map look like?
il try swapping them over tomorrow, but im pretty sure they are on right.Gunni wrote:I´ve seen it a million times, it´s the hose pipes on the wrong way ;)
- Retired Team Member
- Contact:
back of head to bottom matrix hose.
exp tank hose runs to upper matrix hose
it will not bleed without these correctly fitted Sean.
Email FTW
sound, cheers, il take a look in a bit!!!
Nice thread, been reading through, this one sounds like one to watch out for!
How much did you take off the pistons to bring the cr down to 8.0cr?
Looking forward to heaering about the running of this one!
just the squish was taken off, there is still a bowl in the top of the piston, also had deep valve reliefs cut for the more agressive cam.
took it out for a spin before but still very lumpy...
double checked it and they were on the right way, looks like its just got to be bled.Ant wrote:back of head to bottom matrix hose.
cat cams, turbo cam.
ant supplys them.
ant supplys them.
couple more pics from today....
not happy though a i still cant bleed the coolant!!!!
Did you fill it slowly through the radiator top hose (pouring into the engine) and bottom hose into the rad?
Thats how i did it on the 320 and it bled up straight away.
I also had it on a pair of those steel ramps so it was nose up, which helps.
It looks good though, it will all be worth it the first time you bring it on boost and dispatch some council chariot
yep tryd that, rad is full, got it jacked up, still nothing!!
yeah it does doesnt it!
gonna look into getting a custom ally rad made up!
- fowler
- Boost Junkie
- Contact:
na mate just change waterpup for a late one and use post facelift rad and cooling set-up more tha sufficient
EX A-Tech Workshop bitch !!!
gone but not forgotten
it is a post facelift rad ben.
- fowler
- Boost Junkie
- Contact:
with regards to your cooling prob give me a quick call should be able to sort it as i am off home now mobile is below in sig
Right, im at a loose end with this car, i just dont know weather to sell it or keep it.
dont want to sell, but it wont get used.
IF i was to sell i would want to get another but just a 2.7.
anyone have any idea of what it would be worth? its a waste as its cost me around 10k all in and i know i would never see that again.
- Contact:
Are you still having problems Sean?
to be honest mate, i havent even been to my car since the last time i spoke to you, gonna go this weekend and get the new rad in and try sort the ecu to get it running again.
just dont know what to do with it at the mo.
coz i bought the m3, now i want to strip and cage it and il just throw more and more money at it, if i was in the uk close to tracks it would be fine.
