im a complete novice and i believe the power steering belt is loose on my e30 316 (1989). would really appreciate some step by step instructions.
have tried to losen the 3 13mm nuts but the whole thing just turns, what am i doing wrong .... cheers
how do i tighten power steering belt
sparky1972
if memory serves me there is a bolt at the bottom of the pump (13mm) and loosen the bolt on the top of the pump its on a long bit of metal with a slot in it.
get a long bar and pull towards you not too much or you'll overtighten the belt and cause more problems.,tighten nuts up bobs your uncle no more screeching belt on hard lock
did mine took me 5 mins
Ah, women. They make the highs higher and the lows more frequent.
Friedrich Nietzsche
Friedrich Nietzsche
