how do i tighten power steering belt
gazncathy
Wed Oct 01, 2008 6:33 pm
im a complete novice and i believe the power steering belt is loose on my e30 316 (1989). would really appreciate some step by step instructions.
have tried to losen the 3 13mm nuts but the whole thing just turns, what am i doing wrong .... cheers
gazncathy
Wed Oct 01, 2008 8:48 pm
one more thing how long would you expect the job to take just incase i have to pay someone to do it - dont wanna get taken in by a cowboy mechanic, thanks again
sparky1972
Wed Oct 01, 2008 8:57 pm
if memory serves me there is a bolt at the bottom of the pump (13mm) and loosen the bolt on the top of the pump its on a long bit of metal with a slot in it.
get a long bar and pull towards you not too much or you'll overtighten the belt and cause more problems.,tighten nuts up bobs your uncle no more screeching belt on hard lock
did mine took me 5 mins
Ah, women. They make the highs higher and the lows more frequent.
Friedrich Nietzsche
gazncathy
Wed Oct 01, 2008 9:28 pm
cheers, someone told me i also need to loosen the 3 13mm nuts on the pully wheel too is that true?????
Supafly
Wed Oct 01, 2008 11:30 pm
no, you shouldn't need to even touch the bolts/nuts on the pulley wheel.
gazncathy
Thu Oct 02, 2008 6:55 pm
THANKS ALOT GUYS TOOK A COMPLETE NOVICE LIKE ME ABOUT 15 MINUTES TO DO AND THE SQEELING HAS GONE, WOULDNT HAVE HAD A CLUE WITHOUT YOUR HELP, WELL HAPPY
