150mph in a 316i Touring.........?
peachers
Wed Sep 24, 2008 9:06 pm
Well not quite but that is what my speedo was indicating!! Think I must have a problem with it as the past few days my speedo has intermittently been playing up. Driving a long at normal motorway speed it suddenly spins round to max (150mph) where it will either sit for a couple of secs or in the case of yesterday for quite a few minutes before settling back to the correct speed (this is matched by the economy meter show 0mpg - understandable as it only just manages 30mpg at 70mph).
Does anyone have any ideas what might be causing this (I suspect either a dodgy speedo or speedo cable but I aint no mechanic)?
Cheers,
Peter
fuzzy
He who sleeps with "Gingers"
Wed Sep 24, 2008 9:08 pm
sounds like the old corroded cables at the diff sensor on the rear axle problem. check the condition of the last 6 inches before the sensor.
GrindCulture
Wed Sep 24, 2008 9:13 pm
I think you're just under estimating the sheer powaaaahh of the 316i...
Probably is the speedo cables as fuzzy said, replace as much as you can and give the socket in the back of the diff a good clean. Common trouble spot, both my E30s have had this at some point. Indicated 145mph pulling into my girlfriends drive in my old iS :mad:
Not in E30s any more :(
n1tr0_9
Wed Sep 24, 2008 9:17 pm
I think you're just under estimating the sheer powaaaahh of the iS!!!
Wed Sep 24, 2008 9:39 pm
You must of had it de-limited. winkeye
maxfield
Wed Sep 24, 2008 9:52 pm
I opened this thread claiming you had reached 150mph.
135mph is the most my speedo has ever read, chances are it won't ever read that again.
GrindCulture
Wed Sep 24, 2008 9:59 pm
n1tr0_9 wrote:I think you're just under estimating the sheer powaaaahh of the iS!!!
Nah it's got so much more in it :D
peachers
Wed Sep 24, 2008 10:39 pm
Thanks for the replies - will check the cables
Don't think my 316i could genuinely see 150kmh let alone 150mph....!! Oh for a 318is or 325i engine to be dropped in it!!
Wed Sep 24, 2008 11:09 pm
What is the 316i's top speed?
cypriot_boy_2k7
Thu Sep 25, 2008 12:50 am
i got 121mph
Felix79
All loved up !
Thu Sep 25, 2008 2:11 am
If I did 150mph in a touring I think I be leaving a long trail of brown fluid from the drivers seat
Felix79 aka Dan
E85 Z4M Roadster
Morat
Thu Sep 25, 2008 9:14 am
At least they've got a roof :P
George_Of_The_Jungle
Thu Sep 25, 2008 9:38 am
i'v seen 140mph on the dial so (135mph actual) and was supprised how quick it got up there
