1.9 16v transplant,engine wont fit?help!
matt27
Post Mon Sep 15, 2008 8:03 pm
my old engine died,but managed to get hold of a 1.9 16v sport engine from a 318ti compact cheap,my mate tried fitting it today into my 318i e30 but the sump hits the front sub-frame or some thing,finding out more tommorow.wrong engine mounts?he doesnt seem to think different monts will work so im open to any ideas/solutions,help please,fed up of walking!
Jon_Bmw
Dangerous when thinking
Post Mon Sep 15, 2008 8:06 pm
You need to change the sump for an e30 m42 one and also the inlet manifold as well. Trying to think, if your m40 sump would fit, anyone else know?
I have a feeling the bottom part is the same, but the top part slightly different?
monkey
Post Mon Sep 15, 2008 8:07 pm
you will need the e30 sump and alloy engine mounts . think you will need to change the inlet and exhaust manifolds and maybe some other bits too . but i think people have done it before
GrindCulture
Post Mon Sep 15, 2008 10:40 pm
RealOEM suggests that both parts of the sump are the same on M40 and M42, they certainly look the same too :D
I'm not sure if the mounts need changing either or whether the M40 ones will fit? I know the M40 mounts are dampered and the M42 ones aren't but that's only where they mount to the chassis.
Not in E30s any more :(
matt27
Post Fri Sep 19, 2008 10:41 pm
thanks for your advice folks,fingers crossed changing the m44 sump for my m40 sump should do the trick.Just got a couple of questions,sorry if i sound daft but i aint a mechanic,so bare with me.was wondering why i had to swap the air intake manifold for the m42 intake.All so, anyway i can get get away with the m44 exhaust manifold?custom down pipe?cant find any e30 m42 exhaust manifolds locally,would a m42 exhaust manifold from a e36 work?,no probs getting one of those.Just one last thing,oil pick up in wrong place,how do i get round that prob?thanks for taking the time to help me out.
GrindCulture
Post Sat Sep 20, 2008 11:43 am
I don't see how the exhaust manifold would be a problem, as long as it clears the cross member and steering coupling. Not sure about the intake manifold though? It might be to do with a space issue or throttle linkage problems maybe? (not much help there I'm afraid :? )
