Best Stuff for Removing Tree Sap
cliffybabe
- Powered by Nelly
Guys
Whats the best gear for removing tree sap normally i just polish till it comes off but does anyone have any tips or suggestions??
Neil
Neil
benjy
Dont park under trees!
Sorry, couldnt resist!
Try 'muck off' or I think Mequires do something for it.....
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
d6dph
Best way to remove it is by claying the car
cliffybabe
- Powered by Nelly
knew that was comingbenjy wrote:Dont park under trees!
benjy
cliffybabe wrote:knew that was comingbenjy wrote:Dont park under trees!
Had to be said!!
How about traffic film remover??
- **BANNED**
Chainsaw,apply to tree..
cliffybabe
- Powered by Nelly
sounds good to medaimlerman wrote:Chainsaw,apply to tree..
d6dph
d6dph wrote:Best way to remove it is by claying the car
cliffybabe
- Powered by Nelly
thats what im doing tomorrow afternoon thend6dph wrote:d6dph wrote:Best way to remove it is by claying the car
robbo86
then definately dont park under the treedaimlerman wrote:Chainsaw,apply to tree..
Dan320is
Washing it with warm/hot water always works for me.
Thats I would say. If it's only tree sap a wash should do it.Dan325iSport wrote:Washing it with warm/hot water always works for me.
Cotty
- Hartge Crew
But a clay bar will also get rid of other crap as well
d6dph
I'd be suprised if hot water would remove all the sap Trev, Depends on how well protected the surface was before it bonded.B7 wrote:Thats I would say. If it's only tree sap a wash should do it.Dan325iSport wrote:Washing it with warm/hot water always works for me.
You old bus will probably repel dirt with the level of cleanliness you maintain
bodger
autoglym intensive tar remover
OBs
Tree sap is nasty stuff
At work we use 'clean / neat' thinners
Risky business, but as long as you dont leave it on the paint work long its usually fine
TFR dosnt really work that well, but if you put bits of cloth soaked in TFR on the effected areas it will eventually penetrate it... God the times Ive had to flat and polish roofs and bonnets because some tit has used a brillo pad
robbo86
its basically a bar..... and its made of clayH7AVY wrote:Whats the clay bar?
s'why its called a claybar....
http://www.dtconcours.co.uk/super-clay.htm
cliffybabe
- Powered by Nelly
robbo86 wrote:its basically a bar..... and its made of clayH7AVY wrote:Whats the clay bar?
robbo86
I'm clever me!!!
H7AVY
Yeah well done il post you a blue peter's badge!!!!!
robbo86
WOOOHOOO!!!
HartgeH27
But MUST be washed first Diddyman !!! Tut tut...............d6dph wrote:d6dph wrote:Best way to remove it is by claying the car
chrisdovey1
best stuff ive found for this is chemical guys heavy deagreasant, diluted 1/4. spray on, leave for a couple of minutes. then rub with microfibre wash mitt then wash off with jet wash
