The whole project has had it's ups and downs, but, with the help of fellow zoners and friends, we've overcome all the obstacles and built a beauty.
The car started off as a 320i Auto Touring, then.......they say a picture is worth a thousand words, so enjoy.
G88 after picking it up.
The work begins.
ABS retrofit
Clio master cylinder and servo
Spax adjustables with -40mm springs, all new bushes
Engine arrives, M50 from an E34 525i
Cast manifolds off and E36 mounts added
Tubular manifolds, ready to modify to clear the steering column
Quick check over, not bad for 191k
Rewiring C101 to suit E30 plug
And, as if by magic..
More wiring, this time, the ECU and relays
To be continued.....
