my bmws is ressisting to pull away from a red light quick
scotttollan
Hi my bmw 320i m20 is ressisting to pull away from a red light quick.
It also hessitates to rev up for a couple of minutes when reved when stopped. I think it has a flat spot if so can you tell me how to get rid of the flat spot and what is it thats causng this to happen could it be because it could it has been waterlocked before and this is the water coming out now?.
thanks.
thanks.
bmw 320i e30
scotttollan
no i'm not i like bmws and plus i do wait for the green light it just ressites to pull away like from a stop when you put the accelerator pedal down to the floor.
please tell me what is causing this to happen because i would like to get it fixed
honest i do like all the bmws
bmw 320i e30
leeparkes
not sure what you mean,
does it like splutter when you pull off and once your off does it drive ok?
ie hesitating,etc...
- Brianmoooore
It's trying to tell you it needs a good service!
scotttollan
i have serviced it byputting new spark plugs new oil reset the lightsBrianmoooore wrote:It's trying to tell you it needs a good service!
bmw 320i e30
Sounds like it might need more servicing than that...
Is it an automatic? I've never seen an auto (BMW or other) that didn't hesitate a moment before moving off...even the best have a tiny delay between "foot to the floor" and "off we go"
scotttollan
no it's a manual transmissionlloydp wrote:Sounds like it might need more servicing than that...
bmw 320i e30
zimmer-320i
- Contact:
can i say oil and spark plugs arnt a service, needs air filter and oil filter and never use the old oil filter with new oil also full serve includes the ht leads dizzy and rotor
scotttollan
i also done the oil filterzimmer-320i wrote:i have serviced it byputting new spark plugs new oil reset the lights
and then replaced the air filter with an induction kit
i done the dizzy and the rotor arm at the same time
bmw 320i e30
scotttollan
nopeOnz wrote:any strange noises? knocking or grinding? also do your cams whine?
bmw 320i e30
scotttollan
yes it has i'm only looking for answers not any people saying i haven't serviced it
bmw 320i e30
danman2k
you could try unplugging the battery and forcing the ecu to relearn settings maybe. check pipes for splits. change fuel filter. give the car a good sprint on the motorway and see.
getting a chip is suppose to remove flat spots too
leeparkes
i had an induction kit on my 325i and was advised to go back to the standard air box!
on doing this i noticed an improvment throughout (especially on standing starts) e30s suffer from heat under the bonnet
so when your sitting at the lights heat builds up and when you first pull off the induction kit is sucking hot air,hence loss of power!
get a paper element from euro parts for a fiver go back to the air box (you will be suprised)
worth a try!
worth a try!
zimmer-320i
- Contact:
were only trying work out why mate, my inspection light was on but made no diffrence,yes it has i'm only looking for answers not any people saying i haven't serviced it
if you cant source it get a mobile dignostics (sorry spelling
my main advice would be check all electric plugs and earthin point ang go from there
zimmer-320i
- Contact:
yer ive got a apexi filter as it goese30s suffer from heat under the bonnet
- Brianmoooore
These are typical symptoms of a neglected E30, and as I said at the start of the thread, it needs a damn'd good service!!
I'm not talking about just changing the oil and sparkplugs - I mean carefully check out the whole ignition system, check the valve clearances, check the valve gear for wear, check the AFM, check and clean the ICV, clean the throttle body, check the action of the TPS, check the plug and socket for the injector loom, check the blue temp sensor is within spec, check all hoses and gaskets for air leaks, etc, etc.
Or, in short, check that everything works and is adjusted exactly as it was when it left the factory!
scotttollan
Bob_S wrote:does it tap like buggery?
nope perfect
bmw 320i e30
scotttollan
wait a minute how did u guess that was correctAlex wrote:hang on!!! its a m20b20 theres the trouble![]()
it doesn't do it all the time
bmw 320i e30
scotttollan
oh you had me going there
bmw 320i e30
i would do as mr moore says i would also try running it for a day with the standard airbox just to see if this makes a diffrence as i know it has in the past for me
scotttollan
it was doing that with the starnderd aswell before i switched it to the induction kit
bmw 320i e30
scotttollan
yes it idles properly
i cleaned the vacum hose on thursday and it stopped for now hopefully it's away this time
bmw 320i e30
