decided to do some work on the lump while its out the car,ie water pump,cam belt etc...
putting a new exhaust manifold gasket on and one of the studs broke off,
problem is the swine will not come out,
luckily its sticking out about an inch,so i soaked it it wd40 and got pliers on it,
then got mole grips on it and they kept sliping off so i flatened the top and bottom of the thread and still the mole grips are sliping,ive thought of applying heat to it but i wanted some advice first
the last resort is drilling,but that is the last resort!
