E34 525i Water pump change?
ChrisiS
Post Thu Aug 28, 2008 11:31 am
Anyone know how involved a job this is? Somebody has said to me its a right PITA?
Post Thu Aug 28, 2008 11:42 am
Once the fan is off its a piece of piss :)
zimmerbimmer1
BMW Parts Meister
Post Thu Aug 28, 2008 11:45 am
Is The Car M20 B25 (Cambelt driven)
or M50 B25 (chain Driven)??
Andyboy
Alpina Colada
Post Thu Aug 28, 2008 12:40 pm
M20 (F/G/H plate) - pain in the arse. Viscous fan, distributor cap and rotor arm, top cambelt cover, slacken and move alternator and power steering pump inwards, cambelt tensioner and spring. By the time you have gone this far you would be daft not to go the whole way and fit a new cambelt and tensioner - just another six 13mm bolts for the crank pulley and the lower belt cover. You CAN change the pump without disturbing the belt, but it is such an appalling bastard of a job to get the tensioner spring back in that it's often quicker to do the whole thing.
M50 (H/J/K/L/M/N plate). Draw a diagram of the belt run round the pulleys, remove the viscous fan, slacken the four 10mm water pump pulley bolts, move the adjuster down with an allen key and slip the belt off, four 10mm nuts and off comes the pump. Start to finish in an hour if you've not done one before.
On E34's taking the radiator out makes life a lot easier. Filling and bleeding the system is easy if you do it right. Refit the rad, connect the bottom hose. Fit the top hose to the engine only. Slowly fill the engine with coolant until you see it at the base of the hose. Now remove the hose and fit it to the rad, pointing upwards. Now fill the radiator with coolant until you see it at the base of the hose. Now refit the hose completely, top up the header tank, fire it up and go for a brisk drive with the heater set to hot. As soon as the heater pumps hot air out, it's bled. Top up the header tank if needed, job done.
You'd never guess I just changed an E34 rad 10-15 mins ago, would you? :D
Post Thu Aug 28, 2008 2:01 pm
zimmerbimmer1 wrote:Is The Car M20 B25 (Cambelt driven)
Ah, forgot some people still run those boat anchors around :)
ChrisiS
Post Sat Aug 30, 2008 12:22 am
Cheers guys, a mate has been offered one as part payment for a job (hes a builder- the guy for ehich he was building a house extension has run into some financial 'issues') It looks tidy, just wants the water pump doing......
Ta again
Chris
