Starting problems 325i
Ok my 325i has been garged this wile as doing a bit of restoring to it and charged the battery up and tryed to start it, took a wile to start then splutterd around as if getting no petrol and stoped now wont start again! what could be the problem? plenty of petrol in tank.
Had the ecu removed and refitted would that have any effect?
regards Danny
danman2k
removing the ecu will force it to relearn so i think would give you problems like this. if the battery was only partly charged then that could be dead now so might need recharging. give it some throttle next time starting to put some petrol in the system and let it idle for a while.
- Brianmoooore
The ECU will probably have to relearn idle settings if it's been disconnected, but that shouldn't prevent the car from starting.
Pull out the fuel pump relay (orange one, under cover by air filter), and link across pins 30 and 87 of its base, with a short piece of wire. This should make the fuel pump run continuously, and you should be able to hear it.
- SMALLTHING
- Contact:
my m-tec1 has been garged . connected battery up and tried to start it, but it still wont start .theys no spark, its turn on but no start . IM PULLING MY HAIR OUT !!!! its as if no petrol getting they. wont start again! what could be the problem? plenty of petrol in tank.
Had the ecu removed and refitted.
thank for looking any help please
danman2k
Brianmoooore wrote:The ECU will probably have to relearn idle settings if it's been disconnected, but that shouldn't prevent the car from starting.
thats right, ecu removed wont prevent the car from starting but might give the cutting out/idling issues
danman2k
SMALLTHING wrote:my m-tec1 has been garged . connected battery up and tried to start it, but it still wont start .theys no spark, its turn on but no start . IM PULLING MY HAIR OUT !!!! its as if no petrol getting they. wont start again! what could be the problem? plenty of petrol in tank.
thank for looking any help please![]()
did you do what brianmoore said, you should do what he recommends as he will get you going again
- SMALLTHING
- Contact:
i did what brainmoore said but no joy should i be able to smell petrol or hear the fuel pump theys no buzzing from pump can the pump just give updanman2k wrote:SMALLTHING wrote:my m-tec1 has been garged . connected battery up and tried to start it, but it still wont start .theys no spark, its turn on but no start . IM PULLING MY HAIR OUT !!!! its as if no petrol getting they. wont start again! what could be the problem? plenty of petrol in tank.
- Brianmoooore
With 30 and 87 linked you should be able to hear the pump running. or pumps, if the car is pre '88.SMALLTHING wrote: should i be able to smell petrol or hear the fuel pump theys no buzzing from pump can the pump just give up
Check out fuse 11, as that sits between the relay and the pump, but if it's blown, it's probably because the pump is dud.
- SMALLTHING
- Contact:
thank brainmoore i did that !Brianmoooore wrote:With 30 and 87 linked you should be able to hear the pump running. or pumps, if the car is pre '88.SMALLTHING wrote: should i be able to smell petrol or hear the fuel pump theys no buzzing from pump can the pump just give up
it a e reg theys no buzzying from the pump so i think the pump is f@$% so i will be getting a new one
- SMALLTHING
- Contact:
what about the clutch pickup would that do no spark they is petrol i connect a live to the coil still no spark i changede distributor and rotary arm brainmoore please help no more hair left !!!ha-ha
so what about the pickup on the flywheel help !!!!!!
- SMALLTHING
- Contact:
HELLO zoners what a weekend well i sorted the problem
IT WAS THE PICKUP SENSOR !! SO IF IT DONT START CHECK THAT TO !!
THIS IS THE SENSOR !
OUT WITH THE OLD IN WITH THE NEW!!! HA HA GOT HER STARTED WELL DONE SMALLTHING
- Brianmoooore
If the CPS was the problem, you didn't do the pump test correcly! Pump would buzz, whatever state the CPS was in.SMALLTHING wrote:it a e reg theys no buzzying from the pump so i think the pump is f@$% so i will be getting a new one
- SMALLTHING
- Contact:
well i took the fuel line off and turned the key feul came out .they was no spark !!!!. ive bin driving it so it works fine thanks !Brianmoooore wrote:If the CPS was the problem, you didn't do the pump test correcly! Pump would buzz, whatever state the CPS was in.SMALLTHING wrote:it a e reg theys no buzzying from the pump so i think the pump is f@$% so i will be getting a new one
the m-tec 1 lives loving it !
