I'm currently converting my 1999 316i compact with a 2.8 from a 1996 328i saloon. But there are some differences in the x20 connectors....
I have marked those that appear to be a match with a *.
316i compact x20 (car side)-----------------------------328i x20 (engine side)
Pin no. Colour Function -------------------------------- Colour Function
1 YEL - ABS/ASC control unit -------------------------- not used
2 BRN - ABS/ASC control unit -------------------------- not used
3 BLK/GRN - Exhaust gas valve/temp ? ------------- GRY/VIO ?
*4 BLK/BLU - AC compressor relay ------------------- BLK/BLU Air con
5 not used ------------------------------------------------ BLK/GRY Aux. fan/diagnostic ?
6 not used ------------------------------------------------ VIO/GRY ?
*7 GRN - Immobiliser device --------------------------- GRN ?
8 BLK/WHT - Fuse/DME relay -------------------------- RED/WHT ABS ?
9 WHT/GRN - ABS/ASC control unit ------------------- BRN/RED ?
10 BLU/YEL - Reverse light switch ? ------------------ BLU/YEL Static oil level ? (colour matches...)
11not used ----------------------------------------------- BRN/YEL Water temp
12 not used ---------------------------------------------- BRN/VIO Water temp
*13 GRN/VIO - Fuel pump relay ---------------------- GRN/VIO Fuel pump
14 WHT/VIO/YEL - Fuse/OBD con. ? ------------------ not used
*15 BLK/GRN - Unloader relay ? ---------------------- BLK/GRN Unloader relay
*16 WHT/YEL - Diagnostic/DME ----------------------- WHT/YEL Rx data/diagnostic
*17 WHT/VIO - Diagnostic connector ---------------- WHT/VIO Tx data/diagnostic
*18 BLK/YEL - Starter ----------------------------------- BLK/YEL Starter
*19 WHT/GRN - Diagnostic/instrument cluster ------ WHT/GRN Service reser/diagnostic
*20 BLK - Various control units ------------------------ BLK Various control units
*21 GRN - DME/ignition switch ------------------------- GRN Igition
*22 GRN/WHT - Fuse/various control units --------- GRN/WHT Fuse F26/ various sensors etc.
*23 BRN/GRN - ? ----------------------------------------- BRN/GRN Oil pressure
24 GRN/YEL - OBC --------------------------------------- WHT/BLK Fuel rate/MPG (a match?)
*25 BLU Instrument cluster ---------------------------- BLU ignition warning
The colours were read from the connectors themselves, it's just some of the functions I'm not sure of.
Could people PLEASE fill in the blanks or correct any mistakes.
Also are they all necessary - sounds daft, but for example would the '96 328i saloon of had ASC like my current car...?
Many thanks
