E30 with E39 M5 Power
bmautosport
- Unapproved Trader caution
Yeah i do remember that you wanted them for something else but you were using E36 suspension.The wheels are a low off set of 13mm i think and are 8.5inc wide,and the tyre size is wrong for the E30,you really need an 8inc rim on the front with a 205/40 or 215/40/17 tyre,and a 20mm off set that should be ideal for the front,im not sure on the rear,i have not got that far yet!,but i would say you could use a 8.5 ormaybe a 9inc rim with a 20-25mm off set running a 225/35/17 tyre or idealy you could do with a wider tyre,but its hard to get the right profile,say a 245/30 or 35/17.A bridge you will have to cross when you come to it!.A wheel that suits these cars is the cross spoke styling 5 from the E39 5 series,in 8inc all round or 9inc rear (if they go on!).Keep up the good work!
Simon
Agreed!bmautosport wrote:A wheel that suits these cars is the cross spoke styling 5 from the E39 5 series,in 8inc all round or 9inc rear (if they go on!).Keep up the good work!
c76jon
yep ill go with that!!!!! lolSimon wrote:Agreed!bmautosport wrote:A wheel that suits these cars is the cross spoke styling 5 from the E39 5 series,in 8inc all round or 9inc rear (if they go on!).Keep up the good work!
billgatese30
Simon wrote:Agreed!
hmmmmmmmm..i wonder whyc76jon wrote:yep ill go with that!!!!! lol
glenn
- Engine Transplant Services
yes mike,
a wheel i've really taken a liking to recently is the rondell 058.
with the sizes and offset's i have at the moment,
i could have a 8" rim on the front with a et30 offset,
the rear could be 9" with the same offset
i'll probably sell the wheels i have( to someone with a 5 series),
to fund the new wheel purchase.
i'm not in any rush yet though, still a few months work to do
Richy325iTouring
You got till the 24th july glenn its got to go on the rolers at interpro even if we have to tow it there
320Touring
yup-beast has got to get out to play for the summer!!!Richy325iTouring wrote:You got till the 24th july glenn its got to go on the rolers at interpro even if we have to tow it there
320Touring
glenn
i'm sorry richy, i'll be on holiday then!Richy325iTouring wrote:You got till the 24th july glenn its got to go on the rolers at interpro even if we have to tow it there
didn't do anything to the car last weekend, (had a weekend out of the garage) so monday, after work, i was grinding in the garage,monday night my eye starts itching, tuesday it starts hurting.
this morning i got up and i cant open it, so on my way to work
(at 2.ooam, driving with one hand covering my one eye)
i called into the royal gwent hospital.
doctor found a piece of metal in there.
this is the third time in two years i've had this.
must put my goggles on more often, because they get the metal out with a NEEDLE
Karan
LOL,,,,,what a warrior!glenn wrote:i'm sorry richy, i'll be on holiday then!Richy325iTouring wrote:You got till the 24th july glenn its got to go on the rolers at interpro even if we have to tow it there
glenn
trouble is, i'm sat here sulking 'cos i cant go in the garage andLOL,,,,,what a warrior!
my eye looks like simon13's avatar
Karan
i had solder in my eye and it wasnt pleasant........glenn wrote:trouble is, i'm sat here sulking 'cos i cant go in the garage andLOL,,,,,what a warrior!
my eye looks like simon13's avatar![]()
Toby_Unna
- Boost Junkie
i also don't wear goggles as often as i should
but karan, how the fcuk did you get SOLDER in your EYE!
did it spit cos of the flux, or were you trying to solder something above your head?
Karan
i was applying some force on some wiring... and i slipped and the thingy i waas putting force on flicked back towards me with loadsa solder on it....Toby_Unna wrote:i also don't wear goggles as often as i should
but karan, how the fcuk did you get SOLDER in your EYE!![]()
Toby_Unna
- Boost Junkie
aha, yeah come to think of it iv done that, just been lucky and missed my eyes!
bet that stung a bit
sorry
sorry
Richy325iTouring
thats scareyglenn wrote:trouble is, i'm sat here sulking 'cos i cant go in the garage andLOL,,,,,what a warrior!
id come up but my water pump has died now started pissing water everywhere
i aint happy
something tells me i should have just changed the head gasget that swap engines more probs since than ive ever had
glenn
got the servo/master cylinder on today, had to use an escort servo as the e30 one was too big. have to tidy it up a bit, then i'll put up a pic or two.
or is it the way you drive it
not having much luck lately richy are you!id come up but my water pump has died now started pissing water everywhere
i aint happy
Richy325iTouring
just having bad luck with cars at the moment glenn
will sort it
should allcome right in the end
will sort it
glenn
a few more piccies (now that my eye is better!)
of the servo and master cylinder
and the 'fly by wire' throttle
and the wiring i've got to 'hide'
Karan
good work there again!
i was wondering though when u plumb the brake pipes in ure gonna have pipes going towards the engine cam cover cs of the was the pipes come out thte master... u just gonna make em turn back on themselves as soon as the exit the master?
u got any better shots of how u did the linkages from the brake pedal into the servo..
Widge
Imaginative battery placement. I should think it'll need a small bonnet bulge? No?
Karan
oh and pleeeeeeeasse keep the brown interior and seats.... just whack a fixed bucket for the driver but keep the rest of the stock seats and the brown carpet!
Simon
Nice carpet!
glenn
you lot crack me up (interior)
and are you living on here cos' i only just put them pics up 2 minutes ago.
i'll see if i can get a better pic of the linkage for you karan
Karan
cheers Glenn
as my avatar says... i am apparently engaged to the zone
my post rate isnt the highest but im kinda old skool....
not as old skool as Simon
Simon
I've only just logged on..I don't spend much time on here really
Haha..just noticed..I'm married! I didn't even get engaged....slag!
glenn
widge, i had to put the battery there for now cos' the brain cant be disconnected from power for more than an hour cos' it loses its settings.
and then when you restart it, it over-fuels until its at running temp and the brain relearns its new settings
karan, here's a few more pics, its the best i could do for now.
what i did as a linkage was, modified the plunger arm out of the servo with an eyelet off the link-bar that runs from rhd to lhd, and used the short link piece with the double eyelet to reach/connect.
sounds complicated but you might see better in the pics
Karan
oh yeh i see how uve done it.....good stuff!
TW166Y
this guy is fooking awsome... Wow look at that baby!!!! im so god dam envious, fair play glenn u da man!! that thing is gonna go like fook, maybe you wanna come to stoke and race me in my pathetic 325i sport
im sooooo Green
glenn
thought i'd have a play around with my badge today as it was a bit too wet to go lying around on the garage floor. (or is it my age!!).
it's not the finished thing, but thought i'd leave it like that for a while to see if i like it.
i made the '?' out of the '2'
TOURINGDADDY
Karan
funny as!
e30-320i
damn what a conversion i would bother wit a badging it aint no-one gonna get close enough to see it anyway
89 325i touring
D2LTA
Quite new to the forum and am amazed at some of the projects, this one especially adventurous and impressive......
Respect.... next i'm visitin ma mates in S Wales i'll be constantly looking out for this beast!!!
Mental...
Mental...
316i touring lux
Lancia integrale
Reebok Classic
Marks & Spencers Slippers
Lancia integrale
Reebok Classic
glenn
i haven't done a great deal lately, seem to be busy doing other things.
i've managed to mount the battery in the boot.
hidden all the wires and relays etc that were down in the passenger footwell.
fitted two small cone filters, i've yet to fabricate some surrounds for them to receive a cold air supply.
connected up the vacuum for the servo.
i've also been having a look at fitting ( after i come back off holidays) ,two
extra anti roll bars, two at the front and two at the back, should almost
eliminate body roll.
