is this the correct walbro to buy:
liam012
Post Tue Aug 05, 2008 11:01 pm
as title says- just making sure i am buying one that wwill do as its listed for the nissans but i presume it doesnt matter?...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... ory=122139
OBs
Post Tue Aug 05, 2008 11:08 pm
http://rallynuts.com/motorsport/WALBRO_ ... 0_2802.asp
:wink:
Could of swore I found one for about £55 :?
Buggered if I can remember where :mad:
Turbo-Brown
Boost Junkie
Post Wed Aug 06, 2008 1:45 pm
Hmmm, £76 from rallynuts doesn't sound like too bad a price to me!
Cheers for the heads up on that, might well order a pump from them :D
How much have people paid for injectors too out of interest?
There's some on ebay (440cc ones) for about £260 which doesn't sound all that bad to me.
liam012
Post Wed Aug 06, 2008 2:53 pm
my local gsf stocks them for saab only ??
do you think I would be able to fit the pump to the e30 assembly? or do walbro actually make a different pump for the saab?
isTURBO
Post Wed Aug 06, 2008 5:22 pm
Ive just picked up my set from America and all inclusive it was £171 thats with duties and postage. They were 42lb ones from http://www.deatschwerks.com/catalog/
Also bought a Walbro cant remember which one though and it was around £110 delivered to Ant's place.
HTH
Rivaaj
Imageselling more bunnies to pay for my conversion
e30_Turbo
Boost Junkie
Post Wed Aug 06, 2008 7:39 pm
Mine were new 2nd hand and for about $200.
Came in a ford box tho
fuzzy
He who sleeps with "Gingers"
Post Wed Aug 06, 2008 7:49 pm
liam012 wrote:as title says- just making sure i am buying one that wwill do as its listed for the nissans but i presume it doesnt matter?...
iirc the nissan and the escort cosworth are the same pumps and a direct swap with an e30 pump.i have a walbro 255 escort cosworth pump in mine and that was a direct swap. about £100 iirc
charlE30
Post Thu Aug 07, 2008 7:08 am
Looking for injectors and pumps myself and came across this site http://www.injector.com/fuelinjectors.php don't know if it's of any use to you guys. It's got a good injector calculator on to work out the correct size injector for your engine power. Prices seem really good aswell :D
BMW F31 335d xdrive
liam012
Post Thu Aug 07, 2008 9:24 am
i got my injectors from
http://www.racetronix.com/
About the walbro-
I have tried to buy locally of people who have them for subarus or 200sx but they are trying to convince me not to purchase it as they say the fittings wont be for an e30?
can someone clarify that i will be allright buying these pumpos that i actually will be able to wire and plump them into my e30??
cheers
e30_Turbo
Boost Junkie
Post Thu Aug 07, 2008 5:02 pm
I'm pretty sure they are all the same, it's not like there's much of a design is there, just a round tube like pump.
Toby Unna fitted his and the write up is on here somewhere.
fuzzy
Post Sat Aug 09, 2008 3:40 pm
all my walbro needed to fit was to connect up the wires and solder them together. otherwise a straight swap.
liam012
Post Mon Aug 18, 2008 3:18 pm
for the record the walboro 255 was very easy to fit to the standard e30 pump housing
however the + and - terminals are SO VERY close to the pump housing and i had to resolder on the walboro wires on to the bmw terminals and to be honest i cant relax driving the car - is there anything i can do to ease my mind - i keep ketting visions of the tab touching the housing or the solder braking and me going up in smoke!
was thinking of covering the connections in a non cunductive substance like a 2 pac glue but figure the petrol mightt melt it soon enough.
jmpwr
Post Mon Aug 18, 2008 5:19 pm
I found that with these pumps it is easier to change the terminals. If you leave the existing wires on the e30 housing (just cut the end at the pump and the fit new electrical connectors to the fitting that connects to the walbro pump).
If it eases your mind it is very difficult to set fire to the fuel in the tank as the mixture is too rich to burn (just like when the engine is flooded it wil not ignite the fuel air mix as there is not enough air present ) An empty tank is possibly more dangerous as there is more air so the mixture is possibly in the flammable range.
If you are worried about your soldering I would suggest that you get a second fuel pump holder and change the electrical connectors
