m20 flywheels
owenbach
Tue Jul 22, 2008 8:57 pm
anyone know if an m20 2.0 flywheel is different to a m20 2.5 flywheel
OBs
Tue Jul 22, 2008 8:58 pm
Same :wink:
Tue Jul 22, 2008 9:49 pm
and need lightening!
Tue Jul 22, 2008 9:50 pm
M20 flywheel's not bad for weight - it's the M40 one that looks like it belongs on a diesel.
Dave_M3
Wed Jul 23, 2008 2:08 am
Ahh but you see...
It's to slow the 4 pots down abit so they won't make a joke of the snoby engines :P
Actually glad this came up as a mate is looking into putting a M20 flywheel on a M42 and was wondering if the b20 and b25 were identical since he has a 320 scraped
owenbach
Thu Jul 24, 2008 9:46 pm
so would the 2.5 sport flywheel be the same as well
Thu Jul 24, 2008 10:03 pm
owenbach wrote:so would the 2.5 sport flywheel be the same as well
EVERYTHING about the Sport engine is exactly the same as a 'normal' 325i engine.
march109
Thu Jul 24, 2008 10:06 pm
NO ITS NOT.
For a start there are sport pistons, sport rods, sport louvred head, sport cam, sport crank, sport cankle knackers, sport head bolts, sport ventilated sump ect ect....
:rofl:
Theo
Thu Jul 24, 2008 10:11 pm
Worth noting that the prefacelift 325i uses a unique flywheel. It has the pickups for the crank position sensor mounted on it, and without these the car won't start.
Sat Jul 26, 2008 9:56 am
Theo325 wrote:Worth noting that the prefacelift 325i uses a unique flywheel. It has the pickups for the crank position sensor mounted on it, and without these the car won't start.
you can use these on a facelift engine though!
Sat Jul 26, 2008 10:13 am
i hope so I have just done this 8O
