Hottuning 6 Branch Manifold £200 posted
Enter a group buy or look here for zone discounts
Post Mon Jul 21, 2008 2:21 pm
Nice work, looking good! Can't the oil filter housing be turned 180 degrees to avoid the need to remove the front manifold each time you do an oil change?
gooner1
Out humping Reindeer
Post Mon Jul 21, 2008 2:30 pm
Good work James, and an informative write up and pics. No excuse now for me not fitting a 6 branch now. Apart from the hassle with the oil filter.
john325tewerin
Thanks James for taking the time to post that.
You happy with the drive ie. the sound, performance etc (if any different)?
I wonder if that problem with the oil filter is a common one with tubulars.
Jamese30
Post Mon Jul 21, 2008 4:23 pm
Hi Guys,
Speedtouch,
That unfortunately (unless I am mistaken) is the natural orientation and location position of the oil filter with the standard BMW sandwich plate on - if it is rotated the solid pipes will no longer run correctly to the cooler.
Gooner1,
Oil filter removal should only be a problem with the oil cooler option fitted. However, it is not a major job to unbolt the front 3 branches to get the filter on. You don't need to fully remove it you just need to pull the branches off the studs so there is enough clearance - you "might" even get away doing this without undoing the U bolt underneath.
John325tewerin,
No problem at all, anything to help. The drive is good with it on. Admittedly I have only done a down the road and back run, as I did not have time and the 327i is not my daily driver (it's too pampered!) so with more miles I will give more feedback. I am also still awaiting the bung from e-bay so I borrowed the lambda off my 320i, which I don't want to ruin hence reduced test run (nothing to connect the terminals too, apart form wrap them around the gearbox mount).
The engine note is noticeably higher actually, from the engine end. You still get the nice deep roar from the exhaust-that has not changed, but the burble from the 325i manifold and any engine noise transmitted from the head is replaced with a higher clean note around the manifold. It is different, but I like it.
I will let you know on performance. I wish I had the money to roller it before and after, but unfortunately I don't - it would have been interesting. I will let you know if there are any improvements in driveability though.
James
BMW E30 327i
Mini Cooper S
shorty73
Post Mon Jul 21, 2008 8:47 pm
James I've got one of these on my race car now and I haven't needed to remove the manifold. It's fiddly and messy but it will come out. I was going to put in a remote filter head but for the time being Ive just wrapped it in heatwrap. I change my oil and filter every race so If it doesn't get on my tits, it won't bother you every 6000 miles or so :D
Definitely feels better than my old exhaust but I've had this mated to a one off single exhaust system so it's lighter too and this also makes a big difference.
Go out and thrash the spuds off it if you haven't already. It goes a lovely purple colour!! Sad I know but I like that kind of thing winkeye
See us in www.racingsaloons.co.uk helped by,
alloyproducts for alloy fabrications
www.motorsportoils.co.uk for Lucas oil
www.zeroexhausts.co.uk for the noise
MTech 07831831846 for an engine!
AlpineAde
Post Tue Jul 22, 2008 8:32 am
Mine is in the process of being ceramic coated. I'm also sourcing a hi-flow dual inlet cat. I'll let you guys know how it all goes. I do know of one set (but of our Australian group buy) that is being run on a supercharged E30. The buyer seems very pleased.
I will also try to do a dyno before and after.
Nice write up, James. :thumb:
Jamese30
Post Tue Jul 22, 2008 12:40 pm
Cheers Guys,
Not too worried about the oil filter thing - like you say it will only be every 6k, and all the stuff on the head is new as the engine has only done 1500 miles since a full rebuild, I replaced the oil filter last weekend at the same time - so I should be safe for the next 6000 miles winkeye . I suspect (putting my Engineer hat on :mad: -sorry!) it will be a case of part to part variation with the exhaust manifold....as mine is literally 2-3mm in the way of preventing the oil filter from going on....
AlpineAde - please post some pics, would love to see it, and youshorty73!! Is yours in the Kumho race series?
James
BMW E30 327i
Mini Cooper S
shorty73
Post Tue Jul 22, 2008 4:57 pm
Check my Avatar and sig mate! Definitely not a Kumho sticker 8O
I'll get some photos when I remember to take my camera with me next time I'm on the car.
I've got an assortment of different oil filters down with the car (BMW,Purolator,etc). Can't remember of the top of my head but when I stood 3 of them together one came up a touch shorter. Might have been the purolator one. I'll check for you as it might save some grief.
It wouldn't be too much trouble to put in a remote head if you've got room?
Jamese30
Post Wed Jul 23, 2008 8:02 am
Sorry Shorty,
I was thinking about the spec, and that PBMW can't run modified manifolds so I thought you were in what used to be the "Kumho Challenge".
Just checked out the links though, and very impressive.
Would be interested to hear on the oil filter sandwich plate, although I am not too fussed on dropping the front part of the manifold off for servicing.
My PBMW car has its standard manifold on so I won't have that fit problem on that, as like you I will probably be changing the oil after every race or every couple - when I finally get the thing finished!!!
I'll have to start posting some pics of my build up...
James
BMW E30 327i
Mini Cooper S
AlpineAde
Post Wed Jul 23, 2008 8:05 am
Jamese30 wrote: AlpineAde - please post some pics, would love to see it
I'll see what I can do.
I'll post 'em when I got 'em! :)
Just got to get the manifold coated and the cat sourced.
Jamese30
Post Wed Jul 23, 2008 10:16 am
AlpineAde,
Ok. Looking forward to seeing it. Good luck with the cat.
Cheers,
James
James
BMW E30 327i
Mini Cooper S
shorty73
Post Wed Jul 23, 2008 7:37 pm
No worries mate. You'll be able to run your car in ther TTRS as well as there eligible as Class f cars. You'll get more racing for the money that way. Put some pics in the Motorsports section soon fella.
Jamese30
Post Fri Jul 25, 2008 10:48 pm
Cheers Shorty,
Will have a look into that. On hols next week but will post some pics when I'm back.
I have another delay now, as car is in storage until I move house....
James
BMW E30 327i
Mini Cooper S
325ialpina
Post Sun Aug 03, 2008 8:04 pm
Are these still avalible?
john325tewerin
Post Mon Aug 04, 2008 7:49 am
john325tewerin wrote:
hottuning_eu wrote:Good morning all!,
Maybe it is time to start a new groupbuy for the manifold!
We can start todat with that. And let´s see if we can get a number of 10 people again.
We can do it the same at the first group buy 200£ posted to the UK.
Best regards,
Louise
Hottuning_eu
What the hell! For £200 I'll give it a go, as long as the problems have been rectified now.
1. John325tewerin
2.
3.
4.
5.
6.
7.
8.
9.
10.
Apparently yes. :)
jmpwr
Post Thu Aug 07, 2008 4:45 pm
I would be interested in one of these
john325tewerin
Post Thu Aug 07, 2008 4:57 pm
I shall take the liberty and add you to the list - if that's ok with you. (remove your id if u not agree) :)
1. John325tewerin
2. jmpwr
3.
4.
5.
6.
7.
8.
9.
10.
325ialpina
Post Sun Aug 10, 2008 9:33 pm
And me
1. John325tewerin
2. jmpwr
3. 325ialpina
4.
5.
6.
7.
8.
9.
10.
325ialpina
Post Sun Aug 10, 2008 9:35 pm
At £200 im in winkeye
gooner1
Post Tue Aug 19, 2008 12:53 pm
325ialpina wrote:And me
1. John325tewerin
2. jmpwr
3. 325ialpina
4. gooner1
5.
6.
7.
8.
9.
10.
Be rude not too.
zimmer-320i
Post Wed Sep 03, 2008 3:17 am
this still on? or able to get more must surly be 10 more ppl intrested at that price!!
zimmer-320i
Post Wed Sep 03, 2008 3:31 am
sorry didnt read the last pages, :mad: :roll:
zimmer-320i
Post Wed Sep 03, 2008 3:48 am
sorry to post again, so the problem with connecting and fitting to head is sorted? also is it better to have this cross over pipe or have two single pipes made up? i just see this cross over pipe as a restriction disturbence of gass flow??!! :mad:
zimmer-320i
Post Wed Sep 17, 2008 5:46 pm
ok spoke to hottuning and he is willing to do another group buy and i belive he is willing to do a rolling group buy so its still £200 posted and thats not bad if you consider postage is proberly £25
so get ya names down and hottuning bloke will be on here soon i guess winkeye
zimmer-320i
Post Thu Sep 18, 2008 12:15 pm
so any one intrested in this??? i mean its £200 for 6 branch manifold? plus hes said the fitting problems have been rectified and there shouldnt be any problems this time
TrickyDave
Post Thu Sep 18, 2008 1:26 pm
I'm very interested, but can't commit right now for 2 reasons:
1) I'm skint until payday!
2) I've got a spare M50 engine sat in the garage that I keep threatening to chuck in instead of the M20, so it would be a bit of a waste.
I assume that the M20 manifold can't be used on an M50 engine?
I've subscribed to this thread, so will confirm / retract interest as and when the list gets close to 10 people...
Dave
zimmer-320i
Post Thu Sep 18, 2008 2:10 pm
all 6 cylinder engines beeing
BMW E30 320 I '88-'91
BMW E30 320 I CAT > ' 87
BMW E30 320 I TOURING '88-'93)
BMW E30 323 I CAT > '87
BMW E30 325 I '88-'91 CABRIO
BMW E30 325 IX '88-'91
BMW E30 I TOURING '88-'91
BMW E30 325 IX TOURING '88-'93
but not sure on the m50 sure some one can say yes or no
carannc
Post Thu Sep 25, 2008 7:56 pm
1. John325tewerin
2. jmpwr
3. 325ialpina
4. gooner1
5. carannc
6.
7.
8.
9.
10.
Be rude not too.
count me in
