Auto Gearbox Advice ?
12345kevin
Post Mon Jun 27, 2005 11:55 am
I was on a dual carriageway and cruising at about 70ish, I put my foot down to overtake. The gearbox "kicked down" to what i assume was second gear as the engine hit the rev limiter. I backed off the pedal and it changed up OK.
I tried this a few times with the same result
Is this normal ?
The gearbox has no problems as far as I can tell, it changes very smooth etc.
It's a standard auto, not sport.
Any advice welcomed.
Kevin
320Touring
Post Mon Jun 27, 2005 12:07 pm
My dads old 525i e34 had an auto box
there was 2 stages to the kickdown...
1st stage got it to change up at 4kish
2nd stage got it to shift at the redline.
did yours bounce off the limiter, or shift just before hitting the redline?
TOURINGDADDY
Post Mon Jun 27, 2005 12:08 pm
drain the box fluid and change the filter + oring and refill the box try that first then go from there (real easy to do)
12345kevin
Post Mon Jun 27, 2005 3:06 pm
I'll change the oil and filter as a precaution, any idea of quantity and recommended oil ?
It hit the rev limiter as soon as it "kicked down" which was the worrying bit. 2nd gear at 70 !
kevin
