Removing swirl marks from paint(now messing with composites)
Turbo-Brown
Boost Junkie
Post Tue Jun 24, 2008 7:25 am
I've been buying it from East Coast Fibreglass Supplies as they're really helpful if you e-mail or phone them, and they're about the cheapest place I've found to supply the carbon cloth :D
Turbo-Brown
Boost Junkie
Post Wed Jun 25, 2008 1:38 pm
Good news everyone! The carbon fibre has arrived! :D
Hoping the weather will be good this evening so I can go and have a play.
I've prepped the sunroof panel with release agent already for the carbony fun!
oakey
Post Wed Jun 25, 2008 6:09 pm
^ Its slightly worrying how excited you seem about this Alex :P
Perhaps when you become a carbon fiber wizzz you could make a nice plenum to match the itbs? :D
Turbo-Brown
Boost Junkie
Post Wed Jun 25, 2008 9:16 pm
:lol: it's extremely worrying! In a very nerdy way, it's the learning how to do things which gives me a buzz. The end result is almost secondary to that.
Just been out and put a skin of carbon on the sunroof.
I carefully cut the corners so they'd fold reasonably well, then regretted that decision. Also, the fabric is understandably reluctant to move once it's been laid down in the resin so when you plonk it down off centre, it stays off centre :lol:
Anyway, got it wrapped around the edges reasonably well, tomorrow will tell if I've got a carbon fibred sunroof, or a carbon fibre sunroof :lol:
Looks absolutely beautiful though at the moment with the resin wet, distorted weave and all :lol:
Hopefully it can be persueded to part company with the panel underneath tomorrow! :D
d6dph
Post Wed Jun 25, 2008 9:21 pm
Turbo-Brown wrote:Good news everyone! The carbon fibre has arrived! :D
/\ I always get this pop into my head when I see "good news everyone" :D
Look forward to seeing the finished C/F panel
Turbo-Brown
Boost Junkie
Post Wed Jun 25, 2008 9:26 pm
:lol: funnily enough I posted exactly that picture on the E30 tech a while back to compliment the same phrase :D Futurama rules!
I can't wait to see if the carbon will come off the original sunroof!
Next question is, is there a better way of making the cloth go around sharp corners than selotape?
I know vac bagging would be the best option, but second to that.
Depending on the outcome of this, I'll be ordering enough stuff to do the boot next week........keeping the fingers crossed that it does release tomorrow! :o:
march109
Post Wed Jun 25, 2008 10:13 pm
Why are you so scared of vacuum bagging?
Heres what I use:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0039172574
And if they arn't big enough I butcher two bages to make one and seal with gaffer tape.
Books:
Fibreglass and other composite materials published by HPBooks
The Fibreglass manaul published by ??
How to build Fibreglass customs, hotrods and kit cars
and finally simplified airvcraft design for the home builder (small chapter on composites)
Turbo-Brown
Boost Junkie
Post Thu Jun 26, 2008 7:11 am
It's not so much that I'm scared of it, it's just that I reckon something like a front wing would distort under the vacuum as they're quite thin and flimsy.
Could well be wrong on that so will have a look :D
Where'd you get your pump from Gareth? :)
march109
Post Thu Jun 26, 2008 12:44 pm
Turbo-Brown wrote:It's not so much that I'm scared of it, it's just that I reckon something like a front wing would distort under the vacuum as they're quite thin and flimsy.
Who needs a pump?
With the link I posted you just use a real life home spec vacuum cleaner, theyseal up a treat too as they are designed for clothes storage!
Turbo-Brown
Boost Junkie
Post Thu Jun 26, 2008 1:49 pm
Aaaaaaaah! Cunning :D
Do you use breather membranes and peel ply and all the other gubbins or just lay up and bag?
Do you reckon something flimsy like a wing or a door skin would bend in a vac bag though?
march109
Post Thu Jun 26, 2008 3:03 pm
Yes I use a breather membrane, seems to help and allows for air flow to aid curing, If you are doing something flimsy its all down to what your moulding it off of, if that original piece is stiff enough then the vacuum just presurises the laminate to it and the original piece provides the strength until the laminate is dry and can be removed from the vacuum.
I've also done roofskins by using sand, mould is placed on the floor (if neccessary sand placed and shaped underneath to stop collapsing of the mould) Laminate over the mould and then breather sheets and a plastic sheet placed on top and then added pressure using the mass of the sand by burying it, wait until it cures and the plastic sheet is pulled off carefully so that all the sand is dragged off. And then pull up the laminate and mould together and seperate.
When vacuum bagging you will vac bag the mould too, imagine in this case your doing the boot skin you laminate it all up so you have the CF laminate curing on the boot and then place it all in the bag, breather sheet it and seal it up vacuum it so the prussure is increased the laminate would be forced (due to the vacuum) against the metal boot skin it would provide constant pressure uniformly along the shape, effectivly holding it down and stopping any area lifting or distorting, As if you were able to hold all the areas down as it cured yourself.
Does that make any sence or would pics help?
Turbo-Brown
Boost Junkie
Post Thu Jun 26, 2008 9:37 pm
That does indeed make sense dude :D
Pics are always good though if you've got some to post! :cool:
Released the CF from the sunroof this afternoon (phew, it came off!!)
Some bits of it are really well wetted out and have no air bubbles, whereas other bits are crap, so more attention needs paying to the whole area with the brush next time.
It's also very flexible so my plan of laying up another layer on the inside is out the window :lol:
So, we're back to mould making!
Need to find a way to get the fibreglass mould to faithfully follow the edge of the panel somehow, I wondered about perhaps draping a bin liner over the panel with weighted edges so that the natural spring of the glass doesn't make it lift off. I'm pretty sure that bin liners don't stick to the resin so that should peel off fairly easily to allow the laying up of further layers. Just been reading in my book that vac-bagging polyester can suck all the something out so it doesn't cure properly.
Just to get my carbon fix this weekend, I'm gonna have a go at making a little spoiler by laying up some 100mm wide cloth on a length of guttering to give it some curvature. Should be a laugh :lol:
march109
Post Thu Jun 26, 2008 10:24 pm
Theres nothing stopping you adding another coat of resin to the outside now. Treat it like doing paint work,
ie: do one layer let it dry, do another layer let it dry, wet and dry paper it to flat it back if its thick and smooth enough for your liking then polish to a clear finish again and then protect with some form of clearcoat from an aerosol a UV filtered coating would be good too. If not paint on another coat of resin and repeat until desired thickness and uniform smoothness is achieved.
For strength cut a square of CF the size of inner sunroof skin (size and shape), lay either paper rope or string impregnated with resin in a criss-cross pattern on the inner side of the CF sunroof then cover the smaller CF sheet with resin and place resin side down over the criss-crossed paper rope or string, then roller it down, the inner side of the sunroof piece when dry will look like it has a honeycombe type pattern 'under its skin', I defy you to say it is now too weak. :D
Turbo-Brown
Boost Junkie
Post Tue Jul 01, 2008 7:26 am
Gonna laminate another layer, just a small one onto the CF bit I've already made to see what kind of effect it has on the stiffness.
Have alse prepped the sunroof again so that it has a generous margin (well about 1.5") around it's edge. Have given the margin a couple of degrees of draft to make release easier and also to give something to stick the vac bagging materials to.
Found this place: http://www.svsp.co.uk/Shop%20Website/pa ... erials.htm which seem to sell the materials at reasonable prices, whadda we think?
march109
Post Tue Jul 01, 2008 11:45 am
That is very good pricing I've always just bodged it! At those prices it might be worth doing it properly. Sadly though vacuum bagging won't make the part much (if any) stronger thats all down to design and essentially thickness. With single skin parts its bestto just accept they will be flimsy, or alternativly go for double/triple skin or use reinforcements they will still be much lighter than the metal panels they replicate.
Turbo-Brown
Boost Junkie
Post Tue Jul 01, 2008 1:35 pm
The biggest attraction for me to the vaccing is getting the CF to go into tight corners.
I reckon a double skin should be stiff enough for the sunroof as it'll have a lip around it's periphery, and that a double skin with X-bracing will be enough for the bonnet and boot panels.
That said it's easy enough to add another layer if needs be I guess.
Turbo-Brown
Boost Junkie
Post Tue Jul 01, 2008 8:57 pm
Ah haaaa!
Looks a lot better this time around!
Lesson one learned today are that if you give the pattern reasonably large margins (40mm in this case) you can get Chopped Strand Mat (CSM) to make a sharp bend and stay down in the surface tension of the resin.
Second lesson is to keep a pair of scissors handy so that once you've laid down a sheet of CSM, you can cut and overlap bits which need to make tight compound curves. For example the corners of the sunroof can be made with two cuts each.
Lastly, I think due to the stiffness of the 300g/sqm CSM I used for the second layer, it was trying to lift just a little at the edges where it didn't really want to make the 90degree bend.
This was solved with a sheet of thin plastic, weighed down at the edges with old chair legs taped on :lol:
Plan tomorrow is to remove the plastic sheeting (I hope!) and then apply another two or three layers of 300g/sqm CSM.
Final lessons are that paddle rollers do an excellent job of getting air out of the laminate and that if you don't use a pot with a bloody hole in the bottom to clean brushes and things in, you won't end up with sticky hands :lol:
march109
Post Wed Jul 02, 2008 11:33 am
Oh dear you are having an adventure arn't you!
It is sooo easy most people regard composites as a black art and its all very simple, and year 8 art student could do it given the tools. Its good to see your coming on leaps and bounds.
Turbo-Brown
Boost Junkie
Post Wed Jul 02, 2008 1:47 pm
:lol: It's easy when you know how I guess, but I still have problems with simple things like putting the bloody fabric down where I need it!
Had to lift and reposition the tissue layer three times yesterday before it was central :lol: And by that time it was starting to fall apart.
I'm reasonably confident that this one will be a usable mould in which to make a half decent CF sunroof, and it's been an invaluable learning experience :D
Turbo-Brown
Boost Junkie
Post Wed Jul 02, 2008 10:29 pm
Bloody hell it takes a long time to make a mould!
Just done another two layers of 300g stuff. Keep mixing JUST enough resin and getting it all done by the skin of my teeth, but there's no science to my calculations!
Today I thought, "right; two plies of 300g stuff means I need about 400g of resin".......which would be about right if each ply was 1sqm....but it's about half that!
Anyway, couple of layers of 400g stuff tomorrow plus some bracing and I reckon it'll be time to release it from the pattern 8O
Turbo-Brown
Boost Junkie
Post Sun Jul 06, 2008 4:40 pm
Wahey! That was easy!
Pulled the cardboard and sticky-tape margins off, had a very gentle lever at the old sunroof attachment points and out it popped!
Just gotta order up enough materials to get on with the business of CF sunroof making now :D
It's amazing how light and stiff the mould is! Despite the thickness of the layup it's still lighter than the standard panel!
march109
Post Sun Jul 06, 2008 5:55 pm
Nice one, so the mould is done, time for some carbon wrongness now!
Flozman
Post Sat Jul 12, 2008 8:16 pm
This is a good thread, more updates please!
Turbo-Brown
Boost Junkie
Post Sat Jul 12, 2008 11:07 pm
Cheers dude, will be starting work on the mould for the boot lid tomorrow if the weather's nice.
Will hopefully be getting some vacuum bagging materials together early next week so I can have a proper crack at making the carbon sunroof panel.
1an
Post Sun Jul 13, 2008 11:19 am
looking good Alex,
out of intrest how are you going to fit the carbon sunroof pannel? same way as you would a standard one?
Turbo-Brown
Boost Junkie
Post Sun Jul 13, 2008 3:14 pm
I wanna ditch all of the opening mechanism and just bond the panel in.
Does pose the question of what to do with the hole in the head lining though :lol:
1an
Post Sun Jul 13, 2008 4:42 pm
ooo sounds exactly what i want to do, dont suppose you have any plans to make them to sell a couple?
Turbo-Brown
Boost Junkie
Post Sun Jul 13, 2008 10:50 pm
I think that if people were happy with the quality of what I'd made I'd be happy to sell them.
My standards are probably lower than the show car people though but we'll see when the time comes :lol:
1an
Post Sun Jul 13, 2008 10:56 pm
i would have one if you were to make some, im not to fussed on a show car piece as its for my track car,
look forward to seeing it all fitted.
Turbo-Brown
Boost Junkie
Post Tue Jul 29, 2008 2:43 pm
Aaaaargh! No free time!
Will finish the mould on Friday and then order the CF to make the first bootlid on the weekend :D
Turbo-Brown
Boost Junkie
Post Mon Aug 04, 2008 9:34 pm
Ooh, it's not come out bad that!
So we now have both boot lid and sunroof moulds done and ready to fill with CF.
Speaking to the guys at East Coast Fibreglass, they said a good way to keep the cost down a little bit for no discernable difference in stiffness is to lay up a CF outer, a diolen middle and a CF inner.
Totally makes sense too as the diolen is just on the neutral axis of the sheet so it's only ever loaded in shear which is a nice easy force to deal with if you're a bit of material :D
Gonna order all the kit I need now :D
So that just leaves FIVE moulds to make :lol:
march109
Post Mon Aug 04, 2008 9:39 pm
Good man, CF boot is my next project.
Turbo-Brown
Boost Junkie
Post Mon Aug 04, 2008 9:44 pm
Suspect you'll do an infinitely better job on your mould that I have. I didn't tape the edges all that well so they're a bit feathery.
Gonna layup a border of 50mm CF tape around the perimeter so the twill edges have something to hide behind.
Have been getting people's opinions (well, my housemates) on how it'll look by overlaying a couple of samples. I think it'll look quite cool myself...time will tell!
march109
Post Mon Aug 04, 2008 9:50 pm
I don't know about that, no workshop with the new flat and all now. So will have to use one of the spare rooms. Though it does make controlling the temperature easier, if a little smelly in the house.
Turbo-Brown
Boost Junkie
Post Mon Aug 04, 2008 10:35 pm
:lol: I had major complaints about the smell when I brought sealed polyester containers into the house there'll be riots if you're living with someone :D
That said, epoxy (well West epoxy at any rate) smells like sugar puffs :)
It's gonna have to be SP 106 for the boot lid though I think as West don't actually say in their literature that you can use it on CF whereas SP specifically do!
