Post
Tue Jul 01, 2008 3:28 pm
How did you get on with your emmisions?
I passed first time with quite high readings but the tester said they're very kind to older cars.
I set my AFR targets for 14.7, 900rpms and made sure it was warmed up before hand, laptop was on and ready but not needed in the end.
This is 1000% better than my last MOT, had to retest 3 times due to ignition problems causing a crap burn, sorted in the end.
My MOT also identified bent suspension which although wasn't a fail on it's own, has since meant I've had to fit a new arm and poss track rod end too, still it's sorted now.
Fozz.
