easy to jump to the conclusion that too many miles chasing 911s at max revs in top has done something nasty to the cylinderhead (i wouldn't blame the poor thing, and it was worth it!!)
however the water pump and thermostat obviously might be bad.
i put the 'stat in a pan and boiled it, it opens about 5-7mm. i searched on another board and read it's supposed to open at 85 degrees and should open about an inch.
is mine ok or should it be opening much further? the pan was properly boiling, and i could easily pull the thermostat much further open than it got in the pan
never had one off or had a problem with one before, so i have no idea
