m50 progress
installed the golf servo yesterday, also single wiper mechanism was fabricated and installed, which took all afternoon!!
m20 fly wheel was touching the engine webbing, which was ground back few mm, as shown in pic,
close up of the area which needed grinding, the lighter silver area,
gearbox was mated to the engine, new clutch kit was fitted aswell, need to tap the engine mount holes.
jaistanley
Most of the E36 325i's have a getrag box that bolts up perfectly and uses the smaller guibo (of course you'd need a 3.15 diff to have the same ratios as an M20 getrag box)... Also I think the M42 gearbox works (which can use the E30 diffs). The only trouble with using the M20 one is that it sits at slightly the wrong angle.
hth
hth
Some sooner than othersJhonno wrote:Quite a few M50's about to be on the road then
what's happend dude?
Trouble at t'mill?
Trouble at t'mill?
finally the m50 is ready to drop in.....
going in....
bit of hustling here and there, block almost in..
atlast, new resting place for the m50...
i found if you raise the front of the car as high as possible, the engine can be moved into place quite easily...
need to find a rad!!!
going in....
thats what i did and went in quite easily, otherwise gearbox was hitting the rack!!You sure? - I thought lifting the rear to drop the front panel and let the engine/box go in straighter?
cheers eko,Looking good Ha22
try to sort the wiring today!!
about 8 this evening the m50 came to life, gave the key to my nephew for the first attempt, he couldn't turn the key, so i cranked it myself and the m50 roared to life, amazing
still loads to do yet, but i know it runs, made my day!!
can't wait to drive it.
Good feeling aint itha22 wrote:about 8 this evening the m50 came to life, gave the key to my nephew for the first attempt, he couldn't turn the key, so i cranked it myself and the m50 roared to life, amazing![]()
still loads to do yet, but i know it runs, made my day!!![]()
Well done mate,all downhill from now
