1994 E36 Engine, which had a cut loom, so put an E34 520i loom on (not sure on age.. Single VANOS..)
Have 3 female 3 pin connectors left over but crank and cam sensors are either wrong peg placement or also female, if that make sense?
Anyone got any ideas?
M50 Wiring issues..
- Homo Hair
The 2 litre engines went through a lot of changes, I had a loom just to nick bits out of and noticed differences with ECU pins also.
I would double check its compatible before going any further
Just looked through realoem and as I thought the part numbers are not compatible between 520i and 525i engines.
jaistanley
Tits.......
I still have scraped knuckles from digging that bugger out.
- Homo Hair
Feck arse tit..
Sure there was a 325i in there.. Stick a couple of plasters on Jai
- Homo Hair
Surely 2.0 cam/crank sensors would do the job?! Same way 325i ones do when you go to 2.8.. Unless the ecu doesnt plug in.. Only other issue would be the pegs on the temp sensors.. Hmm.. Scrappy run take 2..
jaistanley
Chop off the 320i plugs and fit the 525/325 ones, then move the pins in the ecu so they're in the right place?
Sounds like a pain in the cock. There has to be a VANOS 525i in a breakers.
- Homo Hair
If the ECU pins are in the wrong place..
2.0i vanos ecu with sensors and 325i chip?
- Homo Hair
??DanThe wrote:
Just get the proper loom Dan
- Homo Hair
True.. Why do something right when you can bodge it tho
Anyways.. Sorted hopefully
