What Size Speakers Fit?
e30owner
Post Wed May 28, 2008 8:28 pm
Hi guys in need of upgrading my sound in my e30 wanted to know what size speakers would fit the standard rear quater cards and also near the front foot wells.
Thanks.
hongkongfuey
Mad-tango-geezer
Post Wed May 28, 2008 9:32 pm
hello mate , you will get a better response if you put details of your car.
e30's take 5 1/4" front footwells. i'm not sure for cabbies
with cars like mine,
e30owner
Post Wed May 28, 2008 10:04 pm
hi mate its a e30 cabbie sorry forgot to mention.
GDBN
Post Thu May 29, 2008 12:50 pm
Hi there.
Cabs take a standard 5.25" speaker, both front and back.
I recommend if upgrading that you get components for the front.
G
I deserve 6 of the best ...
e30owner
Post Sat May 31, 2008 11:12 pm
Thanks for the advise guys I dont really wana gut holes or mount the tweeters from the components in to the rear quater cards would it be better to get somthing up the market speakers like Diamond 5.25?
If I go for the components would they need to be run from a 4channel amp? I've never really wired any components into a car so dont really know much about them.
Any help would do thanks.
hongkongfuey
Mad-tango-geezer
Post Sun Jun 01, 2008 1:43 am
no components only need 2 way amp , they normally come with a cross over (which seperates bass , mid , treble) and the tweeters can go on the plastic covers by the door mirrors
e30owner
Post Sun Jun 01, 2008 11:46 pm
ok thanks if I was running components back and front would I need a 4 channel amp then? or are you saying 2 channel is ok for front and back?
Regards
J
Golf_Man_Z
Post Mon Jun 02, 2008 8:44 am
e30owner wrote:ok thanks if I was running components back and front would I need a 4 channel amp then? or are you saying 2 channel is ok for front and back?
Regards
J
A set of componants is usually 4 speakers 2 for seach side and can be powered by a 2 channel amp, if you however want to run the front and rear speakers off an amp it a must to have a 4 channel amp (if your not running them off your headunit that is)
hongkongfuey
Mad-tango-geezer
Post Mon Jun 02, 2008 4:07 pm
well put :wink:
e30owner
Post Tue Jun 03, 2008 7:14 pm
Thanks for the advise excellent.
