Just had my m-tec2 kit fitted to my cabby, but both the door pods seem to be cumming up short is this right...?
Please help!!!
tripper.
[/img]Moderator: martauto
Yeah they cut right through the doors of both donor vehicles but not at equal lengths inanvertantly making the doors longer than they should be. Was an absolute PITA to find window glass too.Jon_Bmw wrote:Has the car been cut and shut?![]()
That was just a joke, I hope![]()
Good luck in finding your problem.
Hiya, i think you've just aligned the thing too far back. Easy thing to fix.Tripper wrote:Hi Guys, Back again... Had to take it out of storage and its raining...please see pics!
Take a look at the pics, it seems to be aligned correctly from the rear edge of the door but towards the front arch it seems to have run short...How can these be possible! All pod parts are original m-tec 2 and not the fibreglass type. With all original bmw clips.
No drillings were carried out as the pods clipped staraight into original pre set trip positions.
Please help anyone....![]()
Mine is also originally chromebumber model.j3nks79 wrote:I have a pre face lift cabby with the tech 2 kit on and i was told the pre face lift cabbies were longer???
Cabrio has different side sills than hardtops. You can make the hardtop sills to fit but they won't be pretty or look correct.pegibson wrote:hey there,
how did you get the bottom skirts to fit? i have a genuine saloon kit ready to put on my cab, but the sills are deeper on the cab compared to the saloon.
ive been told by some one to glue them on, as the clips are no good for cab.
cheers
Paul
Doors are the same in prefacelift and facelift cabrios so it doesn't matter which one you have..pegibson wrote:so as long as your cabby is the face lift model, it should fit, but if you have chrome bumper (non face lift model), that would cause you your problems..
hope this helps.
