M-tec 2 Bodykit help!!!! pics!!
Tripper
Mon May 26, 2008 2:01 pm
Hi Guys,
Just had my m-tec2 kit fitted to my cabby, but both the door pods seem to be cumming up short is this right...? :( see pic!
Please help!!! :(
tripper.
Image[/img]
Mon May 26, 2008 2:13 pm
seems like its sat too far to the rear of the car do you have any gap on the door closing edge?
shaudy
Mon May 26, 2008 2:17 pm
mines dosnt go right the way to the end of the door but its only ten mm or so back,would it be 4 back door pods you have?the back doors are shorter than the fronts i think :?
Tripper
Mon May 26, 2008 2:25 pm
Each door pod is aligned to the edge of the door (at the closing end).
You got to admit it doesnt look right? It cant be a 4 door type pod as its too long, so does this mean the coupe and cabbys have different door pods..?
aceraf
Mon May 26, 2008 2:27 pm
Is this a genuine kit or fibreglass kit?
Coupe and cab doors are the same length as far as i'm aware so they should be straight swap between the 2.
That pic looks very wrong :eek:
Breaking 325i Touring
definatly doesn't look right maybe it needs shifting forward so each end is equal I think cabs and 2 doors are the same length door ?
Tripper
Mon May 26, 2008 2:29 pm
I'll take a whole pic so you guys can see for yourself.!!! stick around!!
Back in a sec!!!
SHAKEELE30
Boost Junkie
Mon May 26, 2008 2:41 pm
Tripper, ive heard that convert kit is slightly different to the normal 2 door kit, but the should be a slight gap on the door side but not a great deal....
Tripper
Mon May 26, 2008 2:56 pm
Hi Guys, Back again... Had to take it out of storage and its raining... :( please see pics!
Take a look at the pics, it seems to be aligned correctly from the rear edge of the door but towards the front arch it seems to have run short...How can these be possible! All pod parts are original m-tec 2 and not the fibreglass type. With all original bmw clips.
No drillings were carried out as the pods clipped staraight into original pre set trip positions.
Please help anyone.... :( :(
Jon_Bmw
Dangerous when thinking
Mon May 26, 2008 2:58 pm
Has the car been cut and shut? :eek:
That was just a joke, I hope :)
Good luck in finding your problem. :thumb:
Tripper
Mon May 26, 2008 3:08 pm
Hey Shakeel, I thought the same that the coupe and cabbys were more or less the same type of door pods, but again it does'nt look right and its driving me crazy!!! :x
I really need to sort this out, but do it just buy another set of door pods, what if these too are the same - then it would just be a waste of money.. :(
need some serious cosmetic help here :cry:
aceraf
Mon May 26, 2008 3:22 pm
Are both sides like that?
tonybtonyb
Mon May 26, 2008 3:28 pm
Hi the door pods are fitted like that so they do not catch the wing when you open the door.
Tripper
Mon May 26, 2008 3:33 pm
Hi Aceraf, its the same on both sides.
SHAKEELE30
Boost Junkie
Mon May 26, 2008 3:44 pm
tripper, there should be a gap between the front ones, as tonyb has mentioned, but shouldnt be big gap, compare it to other convertible pictures and see if your gap is more than theirs...
Tripper
Mon May 26, 2008 3:45 pm
Anyone there who can actually help and point me to the right direction...please :cry:
badboy007
Mon May 26, 2008 3:52 pm
ive got a 2dr one and a cabriolet one ill go out and check if they are the same and get back to you, that is very very odd as im certain the 2dr and cabby ones are the same.
SPADGE
Mon May 26, 2008 4:20 pm
out of curiosity what is the length along the top of that door pod?
Martinaston
Mon May 26, 2008 5:20 pm
The shut line at the rear is too small, you just need to shuffle them around a bit to close the gap, the front arch piece needs to come back a bit as well.
There is NO nucleus.
Tripper
Mon May 26, 2008 9:16 pm
Cheers Badboy & Spadge, I'll measure the length of my door pods too and compare our both dimensions let you guys know tomorrow.
But the gap on mine seem too large and very odd looking. :(
march109
Mon May 26, 2008 9:25 pm
Jon_Bmw wrote:Has the car been cut and shut? :eek:
Yeah they cut right through the doors of both donor vehicles but not at equal lengths inanvertantly making the doors longer than they should be. Was an absolute PITA to find window glass too. :D
Just ask a cabby owner and a convert owner to measure up the doors!
Tripper
Tue May 27, 2008 7:46 pm
Hi, just measured my door pod length on my cabby and its coming up at 118cm!!
Is there anyone out there how could measure their m-tec 2 door pods lengths and let me know how short mine are coming up? :(
Just spoke to Stuart at BMW Cotswould supliers as Paul is on holiday, and he seems to think that I may have pre 1990 m-tec 2 door pods. :? After 1990 - 93 they released phase 2 door mouldings, does this sound right to anyone? :(
Taylor325i
Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Tue May 27, 2008 9:08 pm
My car is a 1990 2 door saloon and my door pods measure 118.5 cm.
Taylor.
Tripper
Tue May 27, 2008 9:25 pm
Thanks for that Taylor :)
Is yours a facelift model or pre-facelift?
cheers, tripper
Jonsku
Wed May 28, 2008 7:34 am
Tripper wrote:Hi Guys, Back again... Had to take it out of storage and its raining... :( please see pics!
Hiya, i think you've just aligned the thing too far back. Easy thing to fix.
Here's a pic of my mtech2 (bit crappy, i know), hope it helps.
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
Tripper
Wed May 28, 2008 12:56 pm
Cheers Jonsku!!! :)
Those are some mean alloys!!!! :cool:
j3nks79
Wed May 28, 2008 4:58 pm
I have a pre face lift cabby with the tech 2 kit on and i was told the pre face lift cabbies were longer???
Jonsku
Wed May 28, 2008 5:27 pm
j3nks79 wrote:I have a pre face lift cabby with the tech 2 kit on and i was told the pre face lift cabbies were longer???
Mine is also originally chromebumber model.
Only difference is the rear valance and rear lights. You can't fit facelift bumper without big modifications to the bumber or to the body.
I changed the rear valance / panel and the bits around rear lights.
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
pegibson
Thu May 29, 2008 5:50 pm
hey there,
how did you get the bottom skirts to fit? i have a genuine saloon kit ready to put on my cab, but the sills are deeper on the cab compared to the saloon.
ive been told by some one to glue them on, as the clips are no good for cab.
cheers
Paul
Tripper
Thu May 29, 2008 7:31 pm
Hey Paul,
My bodyshop man had a real problem fitting these on and in the end had to glue these and screw these on. You may notice that along the car underneath the skirts are hanging quite low and I may cut these off? :?
Hope this helps you.
Is there anyone who has a 92-93 cabby with a factory fitted m-tec2 kit, who could measure the length of their door mouldings and give the length? :( Please guys!!! help a fellow zoner out :) I cant stand my pride and joy looking incorrect (i'm sure you agree!) :cry:
I'd then like to go on to purchase the correct door mouldings.... :?
suzie650
Fri May 30, 2008 1:06 am
As Jonsku said, the Tech II kit does leave a bit of the door uncovered (allows you to open your door without smashing the door pods) It's not the prettiest thing, I agree, but it's like that.
Your door pods are aligned too far back (and posibly your wing pods too far forwards, although they should slide into the skirts and butt against the arch lip, IIRC) leaving a bigger gap than intended by BMW.
There is some adjustment possible in the clips going into the doors (they mount into the pod on some sort of "slider")
Get the bottom clips off and give it a gentle tap from the back to align them as required. Put your bottom clips back on and your problem's fixed!
Jonsku
Fri May 30, 2008 7:16 am
pegibson wrote:hey there,
cheers
Paul
Cabrio has different side sills than hardtops. You can make the hardtop sills to fit but they won't be pretty or look correct.
There are some cabrio side sills for sale on ebay time to time (~5 times a year maybe). Good luck searching.
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
Tripper
Sat May 31, 2008 10:26 am
Hi fellas,
I still haven't had my answer yet :?
Does any 1 have a 1992 cabby with mtec 2 kit, who could tell me what the length of their driver door moulding (pod) is??? :cry:
some 1 must have 1 out there... :cry:
pegibson
Sat May 31, 2008 3:36 pm
HI, i dont have a genuine cabby mtec, but as i said earlier, i have genuine mtec 2 kit ready to go on. My cab is a 91, late H reg, face lift model..
I have just measured the top edge of the door pod, it is 1187mm, and also just measured
the door at roughly where the top of pod goes, it measures just 1195mm so not much longer than the pod.
I had this kit fitted on my saloon, I remember the gap was aprox 3 mm each end of the pod on that one, when it was centralised on the door nothing like what you seem to have in your pictures..
so as long as your cabby is the face lift model, it should fit, but if you have chrome bumper (non face lift model), that would cause you your problems..
hope this helps.
Paul
Jonsku
Mon Jun 02, 2008 11:47 am
pegibson wrote:so as long as your cabby is the face lift model, it should fit, but if you have chrome bumper (non face lift model), that would cause you your problems..
hope this helps.
Doors are the same in prefacelift and facelift cabrios so it doesn't matter which one you have..
All he needs to do is to realign the panels..
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
