Colour coding bumpers and mirrors
B51ngh
Post Tue Apr 15, 2008 12:38 pm
Hi Guys,
I'm thinking about colour coding the black bumpers and mirrors to match the body work...How easy is this process? I was told by a colleague that it is a simple matter of rubbing down the plastic, using a plastic primer and then painting. I wanted to double check with you guys in case I spoil my baby 8O
Cheers.
BSingh.
DaveD
E30Zone Wiki Specialist
Post Tue Apr 15, 2008 12:40 pm
remember part of the mirror mount is an alloy and will need etch priming
Golf_Man_Z
Post Tue Apr 22, 2008 10:58 pm
Well I did a very QUICK job this weekend (this are my bodge mirrors got new pair in the shed)
Car currently with the black mirrors (yes thats my dads 525D to the left)
I used light grade sandpaper to roughten the surface (dont forget to wash etc to remove grease etc)
I then masked off all areas I did not want to spray
First coat of Grey primer (build up a few coats or untill you have even coverage) dont forget to wet and dry this is the surface the paint is going to go on
I then sprayed with my cars colour paint (Zinnoberrot) build up a few coats again using wet and dry 1500grit inbetween coats
I will be using clear lacqure for the real job but for this quicky I didnt
Heres the mirror with the masking removed
And the car viewed from the front see the colour coded mirrors?
This is only a rough guide im sure others will have views and ideas (as you can tell I love taking pictures of everything I do, it always comes in use
B51ngh
Post Wed Apr 23, 2008 8:25 am
They are looking very good!! Thanks for the pics, it helps me a lot more than my imagination!!
robbo86
Post Sat May 24, 2008 2:24 pm
sorry to post hijack anyone any idea abot what it would cost to get a set of mirrors done proffessionally
Golf_Man_Z
Post Sat May 24, 2008 7:08 pm
To be hounest the paint job i did on my final mirrors really does look imaculate, but if you want it done pro it depends really you get what you pay for. I would expect anything from £30-60 each depending on type of paint, how much u want sprayed and more importantly the quaility.
Cost be £15 to do my mirrors, paint, sandpaper, lacquer etc etc
dobbie82
Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
Post Sat May 24, 2008 7:43 pm
for the bumpers i would guess it would be easier to get a set of colour coded bumpers then you only need to rub down prime and paint (or just fit them if they are already the right colour!)
e30 related ebay auctions + shop(MY Stuff for Sale), http://tinyurl.com/64aufr
My Feedback on the e30zone: http://tinyurl.com/dobbie82feedback
