Has anyone tried those LED bulbs yet? Just wondered if they were compatable with the check control?
I'm not sure if the check control measures for open circuit (ie blown bulb) or if it looks at resistance?
LED Bulbs
They won't be compatible with the check control, but if you use everlasting LEDs, then you won't need the check control for the lamps you change.
Just disconnect the in and out wires for those particular circuits from the check control module, and join them together.
smithy318i
The rear bulb check for the check panel works by passing a current through coils of wire, and the resulting emf switches reed switches.
The light goes on when there isn't enough current through the coils to generate enough of an emf to switch the reed.
(wrong bulb or fried bulb)
e30nerd
Ahh cheers guys
Thinking about it you are right about the current as in the past I had to fit the wrong bulb tempoarily at that caused the light to stay on.
They are still quite expencive so I'll probably stick to the standard bulbs
Demlotcrew
Most LEDS without some kind of current/voltage filtering wont last very long on any car.Brianmoooore wrote:They won't be compatible with the check control, but if you use everlasting LEDs, then you won't need the check control for the lamps you change.
A
For the price they charge for these things, I would hope all that is built in.Demlotcrew wrote:
A
AlpineCab
I've got LED brakelights / rearlights / sidelights / numberplate lights.
Luv 'em!
Also - if I forget to turn off my lights when I park up (which has been known) - no more drained batttery.
On a white car, the ultra-white slighty blueish number plate lights look wicked - and they are well bright.
Just a bugga about the check panel. Gonna try and wire up some resisters to the LED to see what that does.
Luv 'em!
If you wire in the resistors, you'll increase the battery drain to that of ordinary lamps, and flatten your battery if you leave them switched on when parked!
AlpineCab
F*** me - PhD in Math/Phys - and I hadn't thought of that.
Wasted education
Wasted education
smithy318i
Connect your OBC gong to your doors/lights so you dont leave them on!
AlpineCab
havn't got an OBC - but I do want one. Even better, can I have an Alpina one that goes in the air vent, please? P l e a s e ?
