Air con gas
IB6376CY
Fri Apr 25, 2008 10:43 pm
Can someone tell me which freon is used in the aircon for a '91 325?
Templ8e30
Fri Apr 25, 2008 11:21 pm
Should be R12 (the old banned stuff) unless it's had a conversion in the past, usual way to tell is the charge ports on the metal pipes. If the ports have small metal caps then it should still be the old R12, if it has 2 different sized ports (one blue and one red) the it'll be on the new R134a.
It's illegal here in europe for any garage or air con specialist to recharge any vehicle used on the road with R12. If you do have R12 you'll need to convert it to R134a, the kit is available from BMW for about £90.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
IB6376CY
Sat Apr 26, 2008 12:03 am
Thanks for your quick and useful reply.
Steviec
Sat Apr 26, 2008 9:43 pm
If the system is still in good working order, you dont have to convert over to R134a, there are replacement gases one of which is RS24 (I think). I had mine refilled with this by a guy who knew about E30 aircon systems and it works fine now.
<a><IMG></a>
