hi guys
about to start my turbo conversion engine will be coming out tomorow, to be stripped down and rebuilt still in need of a turbo and a manifold does any one the best place toget a manifold from?? and a rough price also what would be the best turbo? thats not gunna cost a fortune any help would be much appreciated
manifold
fowler
- Boost Junkie
Atech job done number is :01959734518
EX A-Tech Workshop bitch !!!
gone but not forgotten
e30_Turbo
- Boost Junkie
Morat
I want a pony!
fowler
- Boost Junkie
i want 600 ponies but mummy said no !!
lobbo
was hoping for around 250bhp ive seen a couple of manifolds so far im going to be using megasquirt and gunna convert to wasted spark, 42lb injectors, walbro 255lph fuel pump was thinking of maybe a t3/t4 turbo not sure which one yet! is there any need to get an uprated oil cooler? and where could i get sum non stretch head bolts from ive bin scanning the net 4 ages cant seem to source any
thanks guys
thanks guys
Turbo-Brown
- Boost Junkie
If you only want 250bhp, you really don't need 42lb injectors!
e30_Turbo
- Boost Junkie
Hello,lobbo wrote:was hoping for around 250bhp ive seen a couple of manifolds so far im going to be using megasquirt and gunna convert to wasted spark, 42lb injectors, walbro 255lph fuel pump was thinking of maybe a t3/t4 turbo not sure which one yet! is there any need to get an uprated oil cooler? and where could i get sum non stretch head bolts from ive bin scanning the net 4 ages cant seem to source any
thanks guys
250bhp, easy, you don't need 42lb injectors, you could use 30's, but if you buy new you may aswell get the bigger ones while you are there.
MS works fine, walbro worth the money, t3 too small, T4 quite old, GT35 awesome. The stock oil cooler is overkill anyway, will work fine when boosted.
Post up the manifolds you have found so we can all see!
HTH, Mark.
