BIKE ENGINED E30
yamaha1
right guys im doing engineering and i think im fairly confindent it what im doing and have access to plenty tools im getting a 316 as my first car but i have a spare garage and want to make a bike engined e30 has anyone seen or know of anyone whos done this and what were the results
one last question it what is the weight of an engineless e30 cheers tom
Pad
Dont know of any been done, I would suspect they err on the heavy side for a bike engine. Would estimate about 1000-1050 for an engineless E30, probably get it down to 900 by removing everything you dont need?
Good luck!
Good luck!
march109
Given the 325i book weight is 1250kg and M20 engine 117Kg approx, that makes 1133kg
IMO withough some serious weight loss a bike engine E30 isn't gonna move much better than a 325.
maggspower
- Turbo Farmer Tractor Driver
I've got to agree withe the other, guys the e30 shell is too heavy to benifit from the bike engines peaky power delivery.
how about a m20b25 powered motorbike
yamaha1
haa ok thats dissapointing , where is the main weight of the car held ?
march109
Only Single mothers to 10 kids on DSS and benefits need apply to ride (since only they could open wide enough to sit on the thing!)maggspower wrote:how about a m20b25 powered motorbike
jaistanley
Ever been to Braintree? They're ten a penny....
stonesie
yamaha1 wrote:haa ok thats dissapointing , where is the main weight of the car held ?
Err the chassis, the engine is a big heavy lump but as has been said, without that it's still the wrong side of a ton
For a completly deranged/deviant, chav baiting, bike powered nutterwagon...... MK1 micra, rear wheel drive, the grass track versions that are fully stripped can get down to about 550Kg and can be made to handle well.... imagine the spotty chavs face when his 'well fast innet' saxo vtr gets anhialated by a micra
Sorry
yamaha1
haha yeh that was the plan - well the place im working for - if i paid them would most likely build me a new chassi from tubular steal would this be worth it ?
yamaha1
right.... looked into it a bit further and i was gonna cage it and everything so it would be far to heavy for a bike engine sooooo.. basically i was looking for a really revvy but reliable car starting from a 318 or 316 my theory now is to get her on bike carbs (suggestions please) and getting a really light flywheel
oakey
Turbocharged Hayabusa engine?
Cotty
- Hartge Crew
Nah a Reliant Kitten is what you want. Fiberglass, RWD, lovelystonesie wrote:
For a completly deranged/deviant, chav baiting, bike powered nutterwagon...... MK1 micra, rear wheel drive, the grass track versions that are fully stripped can get down to about 550Kg and can be made to handle well.... imagine the spotty chavs face when his 'well fast innet' saxo vtr gets anhialated by a micra![]()
dlatch
my old stripped E30 sport weighed 1050 kg so a bike engine would be rather pointless but sound great
i would say you need a target weight of 500kg to make it worthwhile,
kitten would be ace there has been a few done
madaboutthe30
From what I've seen most bike engines are dopped into minis or smart cars.
Bike engines dont have that much torque thats why there only good only a really light chasis.
If you want something revvy which you could put into an e30, why not try the engine from a type r for example
Dreaming of the day I purchase an E30 M3
--- e30 motorsport cab-- in the process of becoming a trailer queen
--- Z4M Coupe - daily driver
H35-IAN
if you could fit 2 bike engines side by side under the bonnet running a wheel each both tuned , maybe r1 , hyabusa engines together i think that would be more like it , that way if it was stripped out, each engine would only be pushing 525kg each!! now that would f*****in rip!!
ian.
ian.
bmw 328i sport e36
Tommo32
dont forget the infinite weakness of a bike engine, clutch etc.
maxfield
Turbo'ed Hayabusa engine, well 2 of them
Morat
Or just turbo a 325i.... It can't be THAT boring
choppa7
lace1a has bike carb'd a couple of his engines now
He is the man in the know
1990 318i Lux
Ziggy
Ian, you're mad. Mad I tell you.
How 'bout one under the bonnet & one in the boot for 4wd?!
wrcarter
Could get two R1 engines and make a V8. then turbo/supercharge that.
Pad
dubsport have done a few twin engines, not sure any of them have been bike engines though. Saw a Westfield with 2 ZX9 engines in once... nutter.
d6dph
Don't worry, I chuckled at that one!jaistanley wrote:Ever been to Braintree? They're ten a penny....
jkarran
Much is made of the 'peaky delivery' of a bike engine, it's nonsense... you have a 6spd sequental box so if you want more power you just shift down, it takes a fraction of a second. My BEC pulls like a train from 2nd to 5th (it lights the tyres if you push it in first and 6th is merely quick rather than bonkers) and it'll pull cleanly from 2500 to 17500 rpm even under load.
E30 is however heavy for a mere 150bhp engine. To make a quick BE_E30 you'd need to be looking at one of the big 1200 or 1300cc motors (180bhp but much more money than R1). To make a fast one you'll be wanting one in the front one in the back or something like a turbo 'Busa which is capable of 500+bhp if your wallet can keep up.
Clutches need attention, they will melt (mine has lasted a thousand or so miles but post dragstrip session is now slipping) but there's loads of aftermarket bits. Gearboxes are weak especially if you ditch all the impact absorbing drivetrain (so don't!). Gearbox will take even more of a beating in a big saloon than a lightweight 7 as you'll be hammering it to keep the engine on cam. Exhaust wont fit unless you're lucky. Oil system needs attention.
Having built a BEC (and I'm in the process of building another one, a mini this time for a mate) I personally wouldn't do it unless I was going the whole hog, twin 'Busa or '12R, 4WD into a gutted shell.
If you just want a fast E30 then go with a more conventional swap, big capacity or forced induction.
There's a MK2 Escort rallycar with a bike mill on youtube. It's far from slow but I bet it's hard work to drive.
jk
jk
E30 320i Rally Turd - Usually broken
E24 635Csi - Rotting in peace for now
E34 540i - Daily driver
Blown R1 Striker - In progress
andyr
Lol you guys - cheek this the fook out!!! If a bike engine goes like this in a mk2 escort, get the e30 stipped out u'll not be far off!! O it will cost ya some wedge though
jaistanley
Turbocharged isn't it?
stonesie
Yep, nice clear shot of it at the end
jaistanley
I'd quite like to supercharge a Hyabusa lump and try it in an E30... Massive rootes type blower with lower comp forged pistons.
- Homo Hair
Jai.. Concentrate on getting your S50 done 1st yeah
Onz
pre facelift 318 M10 carbed car is 995KG with Engine. Strip it out and seam weld the whole thing you may get it down to 500kgs
- Homo Hair
no chanceOnz wrote:pre facelift 318 M10 carbed car is 995KG with Engine. Strip it out and seam weld the whole thing you may get it down to 500kgs
Onz
how much does an M10 engine, the seats, door cards, sound proofing, wipers/motors, door glass, standard wheels etc weigh?
e21Jason
My Mate in the states runs a s14 powered spaceframed e21 and he only got the wieght down to 780kgs and that with half the shell missing, and loads of carbon panels.
Jason
Jason
jaistanley
I had a 205 GTi 1.9 and gutted it for a bit of a laugh. Seem to recall that only got down to about 750ish (can't remember exactly, old age is setting in).
Tommo32
and dont forget boys to DRILL YOUR DISCS!!!
and the ends of the wheel bolts! so much weight in the head of them!
