Gearbox mount
johnl320
Post Thu Mar 20, 2008 12:12 am
I currently have a home made gearbox cross member supporting my e28 dogleg box. I'm not entirely happy with it so want to get the real deal fitted. What do I need? 323i or m3.
I've checked the ETK and it comes up with different part numbers. Did all M3s have dogleg boxes?
Cheers in advance.
john
Yaninnya
Post Thu Mar 20, 2008 3:39 am
All european.
Jan
johnl320
Post Thu Mar 20, 2008 10:58 pm
Come on someone must know what cross member I need :cry:
Yaninnya
Post Fri Mar 21, 2008 9:32 am
O.K. I'll try again: all european spec M3 have dogleg gearboxes. And M3 crossmember (BMW pn. 23 71 2 225 261) is the one you need.
Jan
johnl320
Post Fri Mar 21, 2008 9:44 am
So the mounting points on the chassis are the same across the e30 range? Thats why I asked if I would need the 323i one because its a different part number to the m3 one. I assumed this would be because of chassis differences.
Thanks for your help
john
jaffro
Post Fri Mar 21, 2008 9:46 am
yeh the mounting points are the same :P
johnl320
Post Fri Mar 21, 2008 10:03 am
Thanks mate :D
john
jaffro
Post Fri Mar 21, 2008 10:04 am
i used a normal 325 one on my m30 box are the dogleg much different?
johnl320
Post Fri Mar 21, 2008 10:09 am
The mounts on the box are very different. Your rubber mounts are on a slight angle where as the M3 ones have a bend in them to take them to a vertical position before they get to the box. The ETK shows this quite clearly but for some reason I can't do a link.
john
jaffro
Post Fri Mar 21, 2008 10:13 am
just had a look they are very different. good luck with it mate my conversion is going lol :P
johnl320
Post Fri Mar 21, 2008 10:17 am
jaffro wrote:just had a look they are very different. good luck with it mate my conversion is going lol :P
Yeah I've seen your getting rid. Cheaply to, I reckon you could have got a lot more mate. Are you keeping the car though??
I already have a mount but it uses 318is mounts on a homemade cross member. Its very strong ( like my engine mounts) but I want the geabox positioning perfect to avoid the prop eating itself.
regards
john
jaffro
Post Fri Mar 21, 2008 10:21 am
im keeping the cab and hopefully putting a m50 2.5 in it. not my choice but long story. :P
johnl320
Post Fri Mar 21, 2008 10:38 am
The car is living on, thats the main thing. It will be better for that conversion, rather than a big old m30 lump
regards
john
I am not very bright
Post Fri Mar 21, 2008 7:34 pm
make your own one it will work :idea:
johnl320
Post Fri Mar 21, 2008 9:12 pm
Read the thread fella :roll:
