Hartge H27 resto
bloom_meister
Post Fri Nov 09, 2007 1:12 am
Hartge springs should be H&R no?
I'm sure someone will correct me but from research the E30 suspension kits from Hartge were Bilstein shocks with H&R springs
Thats the 3rd different type of H27 badge I have seen, there is the simple metal lettering (without black plastic background), the one with the Hartge blue stripes and now this one..bloody confusing.
Tim
E30Mark
Post Fri Nov 09, 2007 8:01 am
Simon wrote:
Can anyone identify the spring..?
Eibach
320i, 324d, 324td, 325i
11.88 - 12.90
F2019001
front axle load 865 kg
Approx lowering front 30-40 mm
http://www.eibach.de/index_2.php?SPA=1&C_lang=en&LN=
PM for details
Simon
Post Fri Nov 09, 2007 12:36 pm
Mark/Barry, cheers for confirming that.
Tim, I know for sure that these are not the original springs, they were changed due to a snapped rear spring which was an MOT failure, it's all documented in the paperwork I have for the car, just no confirmation of the make of spring used. The car still has the bilsteins.
As for the badges, then these are the metal ones you mention, very thin and fragile.
HartgeH27
Post Wed Nov 21, 2007 2:00 am
Update Simon ??
Any new photos ?
Demlotcrew
Post Wed Nov 21, 2007 9:48 am
Hartge springs say hartge on them!
Andrew
HartgeH27
Post Wed Nov 21, 2007 4:14 pm
Demlotcrew wrote:Hartge springs say hartge on them!
Andrew
Simon,
I meant any news in general or any other photos of work in progress ??
Simon
Post Tue Nov 27, 2007 10:24 pm
Not much news really, been really busy with work!
Still hunting a rocker cover and front strut brace, missed out on a strut brace last week, it ended at £155.
The rear strut brace I have is a Hartge item, I've noticed an identical item on the Hartge E30 brochure 8)
Some opinions on the interior would be nice, do I stick with the original 325i sport black leather, or do I fit a really nice E30 M3 black heated leather interior...
Post Tue Nov 27, 2007 10:27 pm
M3 seats stay in M3's if you ask me
Jesus325iTouring
Frog freak !
Frog freak !
Post Wed Nov 28, 2007 12:12 am
If you ever need replacement ones and can't get them,I can do you repro ones from yours.
billgatese30
Post Wed Nov 28, 2007 12:29 am
Simon wrote: Some opinions on the interior would be nice, do I stick with the original 325i sport black leather, or do I fit a really nice E30 M3 black heated leather interior...
i got two fronts if you need them winkeye
parkin10
Post Fri Nov 30, 2007 10:16 pm
i do body & paint 20 years experience! will be nice to see how it turns out keep at it
Andyboy
Alpina Colada
Post Sun Dec 02, 2007 10:33 am
Breaking the Sport would be madness. It's not THAT bad. It needs a good experienced welder to cut the grot out and repair it - What you can do is replace just the inner arch outer halves. That outer arch lip looks like a good clean up with a grinder and a bit of Hammerite will do before some Waxoyl and refit the side skirts.
Even if it costs £1000 to do it, it's still a £3500+ car when done as it's a car with a Hartge H27 conversion and history. The conversion bits relate to that car and not what you might plan to fit it to.
Andyboy
Alpina Colada
Post Sun Dec 02, 2007 10:37 am
BTW Eibach probably make the Hartge springs anyway - they do for Alpina and AC Schnitzer.
ShepsEvo3
Master of go faster
Post Sun Dec 02, 2007 11:04 am
Simon, I think this car needs to remain standard H27.. Although the M3 rear seat looks better you know what the purists are like lol. But its your car :wink:
www.sabre-tuning.co.uk
Simon
Post Sun Dec 02, 2007 12:50 pm
Andy, the car is being repaired, and will see the road again. Won't be an overnight job, as I'm trying to do as much of the stripping/preparation work myself before it's handed over to a proffesional, and that's time allowing at the moment.
Paul, I want to fit the M3 interior, I also think the front seats look better. I'll probably end up keeping the original just in case.
Roger, can you make a good replica of those badges then? If so, I'd be very interested....
Chris, so have I! winkeye
Simon
Post Wed Feb 06, 2008 3:38 pm
Lack of time, lack of updates!
Still in the process of stripping at the moment, found that it still has the original Hartge shocks on the rear...
Fronts seem to be bilstein, haven't pulled them out yet though..
Glad they are the originals, they will be visiting Bilstein for a rebuild eventually.
Exhaust is a concern, someone has fitted that silly flexi pipe to make up the section between the manifold and the centre box.
There's a guy on e-bay.de selling hartge stuff, but it's labelled as H26, would this be ok for this car?
One for Simon13, looks like they are proper Hartge ones, the paint has peeled though..
d6dph
Post Wed Feb 06, 2008 3:59 pm
Nice little update there Simon. Some tasty bits lurking under the grime.
That exhaust is a peach! 8O
HartgeH27
Post Thu Feb 07, 2008 11:59 am
H26 and H27 exhausts the same Simon !!
Simon
Post Thu Feb 07, 2008 1:24 pm
HartgeH27 wrote:H26 and H27 exhausts the same Simon !!
Excellent, thanks Iain!
playo
Post Thu Feb 07, 2008 1:30 pm
Good to see your still at it!
Andyboy
Alpina Colada
Post Sat Feb 16, 2008 10:57 am
That exhaust is so council!
Lovely Billies tho. I bought a load of Hartge shocks from a bloke in 2006 including one pair of E30 ones. A set of Hartge E34 M5 shocks are on my E32. :D
Simon
Post Wed Mar 19, 2008 12:59 pm
Big thanks to Bruce (zedone) for these winkeye
Post Wed Mar 19, 2008 7:57 pm
Any other progress?
StuBeeDoo
Post Wed Mar 19, 2008 8:26 pm
Simon wrote:Some opinions on the interior would be nice, do I stick with the original 325i sport black leather, or do I fit a really nice E30 M3 black heated leather interior...
Recaro's would set-off a Hartge car really well. :D
Simon
Post Wed Mar 19, 2008 8:30 pm
Car is a rolling shell at the moment, and in search of a good enough bodyshop for the work to be carried out.
While things are on hold, I've been on a collecting spree, buying some nice parts ready for the rebuild.
Steering wheel and brand new gearknob
Leather handbrake handle and gaitor
Stripes in grey
Fire extinguisher and bracket
Proper accy tray to sit on the battery cover and 1st aid kit and triangle
Bought new clips for M-tech kit
Sp evo bonnet seals
Pair of almost new smiley headlamps, and front foglights
Still looking for rocker cover and front strut brace.
Post Wed Mar 19, 2008 8:53 pm
Simon wrote:Car is a rolling shell at the moment, and in search of a good enough bodyshop for the work to be carried out.
Beardymatt?
Simon
Post Wed Mar 19, 2008 9:04 pm
Beardymatt?
Ideally yes! But I'm trying to find somewhere local.
A good friend is collecting his motorsport convertible from a bodyshop this weekend, he's a regular at the BMW shows, and is always winning the show and shine/concours, so I know I can trust his judgement on the workmanship.
This place is fairly local too, and looks promising..
http://www.alsaautomotive.org.uk/index.html
playo
Post Thu Mar 20, 2008 12:18 pm
Let me know when you plan on going there Si,
I'll pop along too
march109
Post Thu Mar 20, 2008 12:31 pm
I've seen his work too, Aluns work its top notch, he used to be in Ystradgynlais.
Simon
Post Fri Aug 22, 2008 9:54 pm
Sorry to say no progress, I haven't been in the garage for months now :o:
Had a tidy out in the garage today, and had to move the car, had it running briefly, did a quick sound clip, love the sound....it's very different to what I'm used to an M20 sounding like..
http://s5.photobucket.com/albums/y185/S ... V00366.flv
HartgeH27
Post Fri Aug 22, 2008 11:05 pm
Nice clip/sound Simon........................ :cool:
shafiq
Post Sat Aug 23, 2008 11:37 am
should look nice :cool:
Simon
Post Fri Aug 29, 2008 8:24 pm
Woohoo!
Big thanks to rossle!
spook
League two here we come !!!
Post Fri Aug 29, 2008 8:49 pm
Excellent stuff Simon, those rocker covers sure look good winkeye
Colonel Sanders
Le Surrender Monkey.
Location: guernsey.... i mean france munching on garlic and drinking wine with my children.
Post Sat Aug 30, 2008 7:42 am
glad to see you got it :)
