Any one using AXXIS Ultimate brake pads ?
Andy335Touring
Sat Nov 10, 2007 10:02 pm
CA-Automotive are doing them at a decent price, well compared to some other brands of uprated pads which seem too expensive.
http://www.ca-automotive.co.uk/variants ... ent_id=581
I want them for fast road/the odd track day.
Set up i thinking of putting together is stock discs(may be ATE power discs), AXXIS Ultimate brake pads, steel over-braided brake lines and some ATE Super blue fluid.
iguana
Mon Nov 12, 2007 8:48 pm
Nope but a buddy did in his trackday mx5 mk2 similar weight to e30 & he raved about them, got v good wear out of them.
But im a big fan of ebc yellow on the e30 tracker, v v v v cheap price & wear rates are good.
Big thread I started a while back on seloc ref e3o- pads is good for info, lots of the races rave about the pagid Rs's only prob is they are very very expensive.
www.lizardlogistics.com
Vehicle Transportation Specialists
Andy335Touring
Mon Nov 12, 2007 11:44 pm
That's what i liked when i tried googling them, a lot of positive comments and a lot cheaper than the likes of Pagid/etc.
There was quite a few MX5 boys using them.
UweM3
Wed Nov 14, 2007 1:37 pm
iguana wrote:Nope but a buddy did in his trackday mx5 mk2 similar weight to e30 & he raved about them, got v good wear out of them.
I have used PAGIG Blue and love them! But very expensive..... (£150 the fronts only, ouch!)
I am very tempted to try some EBC yellow, but don't find them cheap enough to take the plunge.
iguana
Wed Nov 14, 2007 7:17 pm
Uwe- £60 a full set i.e fornt & rears inc posage not cheap enough....! winkeye
personally I think they are posibly the best pad for tracaking an e30 in the whole wide world at that price & that still got lots of life left after 2 track days- 1 wet 1 dry
UweM3
Thu Nov 15, 2007 10:05 am
iguana wrote:Uwe- £60 a full set i.e fornt & rears inc posage not cheap enough....! winkeye
sorry should have mentioned that I run 735 calipers which require the same pad as E36 M3. That brings it closer to £90ish IRRC.
Put another 60 on top and I know what I have (PAGID BLue).
I do actually not need very aggresive pads, I am fine with bog standard road pads (£23 the fronts!!!). It's more of a wear issue (20 laps max on the Ring) and I am fed up to change pads in the morning.
UweM3
Mon Dec 10, 2007 10:45 am
I bought a set of AXXIS pads (used) and have tried them in Brands last week.
Can't say anything negative, but weather conditions have been not challenging enough for the brakes to
judge them properly. but very smooth and no judder at all.
Andy335Touring
Mon Dec 10, 2007 7:40 pm
Thanks for the feed back, i've not bought any yet as the track day isn't till february
UweM3
Mon Feb 25, 2008 10:12 pm
Update.
used the pads in Bedford and they worked quite good for a road pad. But for Bedford you need something more track focused IMO.
My car isn't heavy and I run thicker brake disk with cooling to the centre of the disk.
Andy335Touring
Mon Feb 25, 2008 10:20 pm
I ended up going with yellow stuff(also at Bedford on the 9th) due to more positive feed back about them, they lasted well and didn't fade. I had the standard backs smoking a bit but no smoke from the yellows.
Bigger brakes are in the planning now i've got some 16" wheels on so my old calipers/discs/yellow stuff pads will be up for sale.
Jon_Bmw
Dangerous when thinking
Tue Feb 26, 2008 12:01 am
I've recently bought some EBC yellow stuff and they lasted no problem on a 205 which was on slicks. With slicks you get so much more force on the brakes, so I was pleased not to fade them. They don't seem to have worn at all which was a bonus, although its a fair bit lighter than most e30's.
Jon_Bmw
Best bit, £36. :)
moggy
Sat Mar 15, 2008 8:57 pm
I have these fitted to my M5 for the odd trackday.
They are a reasonable compromise IMO for track/road-however I would not feel confident driving to the limit on them as they are not adequate for full on track use.
I did one track day on them where I was using the trackday as a learning experience for the M5.
BMracing
Sun Mar 16, 2008 8:03 pm
All i've heard are good things about the yellow stuff pads, but i'm not sure I want to get them as our car isn's soley for track use. I don't want it to feel like there's no servo when on the road! On the other hand we cooked our standard setup at Snetterton. :?
Sorry if its a bit of a hijack but what discs are good for an e30 on the track? People generally don't seem to rate a lot of drilled/grooved discs. I was thinking of going with standard genuine discs.
Max
