new member problems
Ben5732
Wed Mar 05, 2008 5:22 pm
hey there new member just got told to post this in here so :) have a rather bad problem at the moment, a vibration, i know the alloys are currently slightly warped and had a bit of vibration but it is slowly getting worse to the point its making the dashboard shake between certain speeds, could this be more than just the alloys? the next problem is ive lost access to my boot.... a few days ago went to it in the morning... pushed it in after unlocking the car.... nothing... no click as in it opens, no proper resistance it always moves back into place but doesn't feel right, ive tried opening it with the key but when i put the key in? doesn't even turn, does anyone have any ideas what this could be? thanks. cars an 320i se coupe btw thanks :)
trevski
Wed Mar 05, 2008 5:39 pm
could be your propshaft centre bearing!! mine done this, not an expensive fix!! welcome to the zone by the way!!!
trevski
Wed Mar 05, 2008 5:40 pm
ps wheels being D shaped defo wont help :mad: oh and post some piccys.
Ben5732
Thu Mar 06, 2008 6:29 pm
cheers matey il have it looked at, any idea about the locks?
trevski
Thu Mar 06, 2008 7:01 pm
no sorry
HarvyS
Thu Mar 06, 2008 7:17 pm
Did the boot lock turn before the problem happened? It could be a duff motor, if you cant get the boot open, if you take off the back seat you should see a ski hatch, if it hasn't already been punched out you might need to "create" the hole and then using a long screwdriver you should be able to fiddle the lock open! you'll deffo be able to see whats wrong then! Good luck Buddy. Welcome to the E30 bible!
Ben5732
Sun Mar 09, 2008 2:00 pm
yeah it turned fine, i get the feeling its the spring which has gone and jammed it or something? you know if i did unlock it from the inside could i lock it again? >< prob a silly question but don't want it flying open on my way to work.
thanks :D
Ben5732
Sun Mar 09, 2008 4:32 pm
oh and the pics :)
Ben5732
Sat May 31, 2008 3:32 pm
ok well ive fixed the boot lock on it :) ive changed the wheels so nicer, ive changed the rear drum as it had a big chip out of it ive also done the rear left bearing (narrowed it down to the rear left wheel its coming from after jacking it up) the vibration is no where near as bad, instead of being constant its only happening between roughly 75 - 95 mph and before anyone says it am not condoning speeding this car is going on the nurburgring in just over a month so i need to make sure that this vibration is no longer there for these speeds.
do you think it could be the drive shaft that needs replacing?
thanks for all your help.
tailoutcharlie
Sat May 31, 2008 6:08 pm
may be a stupid question, but you never know, have the new wheels been balanced?
nice clean car btw welcome to the zone :wave:
Chris
SPADGE
Sat May 31, 2008 6:11 pm
Do your alloys have the correct centre bore for the e30?
If not then they should have spiggot rings are these fitted??
hennabm
Sat May 31, 2008 6:27 pm
My 323 had a vibethrough it at 80+. Turned out to be the osr tyre was duff.
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
tailoutcharlie
Sat May 31, 2008 6:30 pm
good point my work van nearly shook my fillings out till a shoddy shape tyre was replaced
Chris
Bob_S
Sat May 31, 2008 7:51 pm
is the vibration under load or speed related if it is speed related it is more than likely to be a wheel problem.. like said above a dodgy tyre, un-balenced wheel or incorrect fitting wheel will cause a vibration
Bollocks to this 24v scrap!
siddiqi1
BFG Zone Contributor
Sat May 31, 2008 9:24 pm
why not the mention of the CONTROL ARM BUSHES everyone? they can cause vibration tooooooo?
tailoutcharlie
Sun Jun 01, 2008 1:34 pm
theres a hundred things that can cause vibration on an e30, I know I replaced them all before I checked how straight my alloy was :evil:
Chris
Ben5732
Sun Jun 01, 2008 6:36 pm
lmao i know it just keeps going no matter what you do! brand new alloys so i know its not them (il get some pics of them up soon) :) also balanced as a mate does it for me, rear tyres are getting changed again soon so il find out if its that thank god. il have a look at the control arm bushes tomorrow after work if its not raining. thanks everyone :D
wrcarter
Tue Jun 03, 2008 7:22 pm
Try the inner track rods too. Sounds just like a problem i had.
Ben5732
Sat Jun 07, 2008 10:18 pm
good news..... today my diff blew..... i think i found out what it is now.... any idea how much it is for a new one on a 320? had a look on ebay only seen ones from the USA so isnt gonna be to easy ><
half of me says sell it.... the other half says get my self into debt n fix it up.... urgh.... love it to pieces but my god is it hurting my wallet
tailoutcharlie
Sun Jun 08, 2008 12:24 am
standard diff wont cost you much at all, first two names on here that come to mind are chrisw or spadge.
if you want to spend money an lsd makes a hell of a difference tho finding one with the right ratio for your car could be tricky
Chris
Ben5732
Sun Jun 08, 2008 7:57 pm
any idea where i can find what ratio mine was mate? or even if the others will fit fine? thanks :)
Ben5732
Wed Jun 11, 2008 1:51 pm
well got another diff... turned out to be the wrong one so swaped around the driveshaft connections and it works:) different ratio seems to give me some more low end acceleration but a slightly higher top speed :) the inside of the old diff was absolutely mashed cogs everywhere took about 4 hours look at it this way.... i was under the car still at 1am never again! got to drive an old mk2 jetta for a few days though was certainly different.... lovely car but makes you appreciate BMs alot more 8) thanks for all your help guys much appreciated.
