2.5 tds conversion
hongkongfuey
Mad-tango-geezer
Post Tue Feb 26, 2008 10:09 pm
i've been wanting to do this for some time, i've been reading another thread and there's too much crap about bio fuels.
i've got a 88 325
all i want to know is what i need, ie engine i know, what gearbox can i use mine or transplant from a 525tds which i hope to get, prop ? fuel system ? dde ?etc.
with cars like mine,
chu346
Post Tue Feb 26, 2008 11:51 pm
hongkongfuey wrote:all i want to know is what i need, ie engine i know, what gearbox can i use mine or transplant from a 525tds which i hope to get, prop ? fuel system ? dde ?etc.
don't this thread tell you most of that?
http://www.e30zone.net/modules.php?name ... ic&t=54992
hongkongfuey
Mad-tango-geezer
Post Wed Feb 27, 2008 8:23 pm
no
chu346
Post Thu Feb 28, 2008 8:46 am
Andyboy wrote:I wouldn't be using an old BMW diesel engine in anything, too much to go expensively wrong plus you have fitting isues such as EWS, fitting a diesel lift pump in the tank etc etc. M51's use Bosch DDE which has an electronic throttle so you'll need to ditch the throttle pedal/cable and fit one of these instead. The M51 is also very heavy. The E36 unit won't fit into an E30 without an E34 diesel sump and yes, they are different to the petrol sump.
Use the M51 gearbox but you will need to change the diff for a lower ratio. Not sure on the prop.
hongkongfuey
Mad-tango-geezer
Post Thu Feb 28, 2008 5:31 pm
thanks mate i was tired when i read it , couldn't see what i was looking at :mad:
