Best engine to turbo? completed & the results are in :)
ross_jsy
Post Thu Jan 26, 2012 1:09 pm
Don't know if this is any help? Going cheap. Was going to buy it today until my promised "big payrise" evaporated:
http://www.e30tech.com/forum/showthread.php?t=111548
Post Thu Jan 26, 2012 1:24 pm
Brady you wrong'un :)
maxfield
Post Thu Jan 26, 2012 1:50 pm
You may be cutting your bonnet if it's going top mounted.
craigieeb
Post Thu Jan 26, 2012 8:27 pm
ross_jsy wrote:Don't know if this is any help? Going cheap. Was going to buy it today until my promised "big payrise" evaporated:
That is a canny manifold, but wrong for my turbo,
the turbo i'v got is a "twin scroll"
so the manifold I/we make will have to be split into 2, say, bank 1,2 and 3 to one side of the "split" T4 flange and 4,5 and 6 to the other side,
and then 2 branch off pipes for the wastegate/s :D
so yeah if i bought that it would just basically get hacked to bits....besides check my sig below :wink:
cheers for the heads up tho dude
E30BeemerLad wrote:Brady you wrong'un :)
Do you want to lick my snail Mr Jones 8O
:teehee: :teehee:
maxfield wrote:You may be cutting your bonnet if it's going top mounted.
No way no how, the turbo will be sitting more or less behind the lights (ish),
There'll be NO cutting of my carbon mr :chuckle:
I'll start a new thread when iv got all the bits and start making the manifold,
Which wont be long now :D
Gunni
Post Thu Jan 26, 2012 10:50 pm
There is NO need to cut the bonnet with that thing.
Alot bigger has been fitted to E30´s without bonnet cutting.
Gunni
@ 2012 VEMS group buy !!
Gunni
Post Thu Jan 26, 2012 10:51 pm
It´s not split pulse which is the prime purpose of the turbo he bought.
Gunni
ross_jsy
Post Fri Jan 27, 2012 10:31 am
See than now I've taken the time to look at the pics properly
mr_dink
Post Fri Jan 27, 2012 10:37 am
Re Vanos vs non vanos lumps, I've had a look into controlling vanos via a standalone such as megasquirt.
Single vanos is pretty much a simple on/off switch, the system is active from just above idle to approx 5000rpm and basically just needs +12V to turn it on. MS can control single vanos quite easily so I imagine VEMS will as well.
As to whether vanos would be a help or a hindrance on a high power turbo motor, I'll wait for someone with more experience to confirm!
craigieeb
Post Fri Jan 27, 2012 4:51 pm
Im not to sure on the vanos side of things,
I think gunni was working on something with the vems, so it could either be controlled or switched off..?? not sure which tho
I played it safe and went for the non vanos, which actually,
turned up this afternoon :D
And after a little fettle looked like this
just need to pull the head tomorrow and give the whole thing a bit of a freshen up
seeing as the plugs look like this,
mmmm Tasty
Post Fri Jan 27, 2012 4:59 pm
Yum.. Sooty!
Dezzy
CR24v it's a lifestyle
Post Fri Jan 27, 2012 7:22 pm
Thats been well looked after!
You fitting a thicker headgasket? I'd defos be getting the head pressure tested and skimmed aswell.
New oil pump inners would be a good idea aswell. That snail will like it's giness to be on tap. :D
craigieeb
Post Fri Jan 27, 2012 7:42 pm
The arp head bolts and the MLS headgasket have just cleared US customs
Dont think the head needs checked, it was running fine when/before it was removed,
and it looks ok to me
It'll not be getting a skim either, it'll mess up the compression
I might treat it to a new oil pump and some new gaskets tho :lol:
Gunni
Post Fri Jan 27, 2012 7:46 pm
mr_dink wrote:Re Vanos vs non vanos lumps, I've had a look into controlling vanos via a standalone such as megasquirt.
Vanos is your friend. The simple M50 vanos any ecu can run, the variable S50 vanos a VEMS can run as well as most (not all) more expensive ones. None that are cheaper then a vems .
Gunni
Post Sun Jan 29, 2012 11:43 am
Crageeb {speed FREAK and ex nitrojunky}
this sounds like fun,giz a shout when the weather gets a few degrees warmer m8 and you have the build car.
many hands make light work :D
craigieeb
Post Sun Jan 29, 2012 3:26 pm
Will do Mick,
need someone to do all the work while im drinking tea and eating bacon sarnies :P
leeparkes wrote:328i/S50 box, there a direct 5th though so you will need a long diff, ie if your going for 500hp it will need to be around 2.93 (or lower)
This blokes got some tasty ratio diffs.
http://www.e30zone.net/modules.php?name ... c&t=209939
Back to the diff situation....
I'v decided Im going to be using the E36 (328is) box,
can anyone work out what ratios will give me what,
I want a diff that is going to give good acceleration and that doesn't run out of puff or be on the limit at around the 150-160 mark
Post Sun Jan 29, 2012 4:31 pm
Gonna need a 2.93 or even lower I suspect..
leeparkes
Post Sun Jan 29, 2012 6:22 pm
Iirc a 3.25 is the equivilent of a 4.0 with an overdrive box and a 2.93 is close to a 3.64.
So yes id go lower than 2.93 with that much power. :)
Nice purchase btw. :cool:
craigieeb
Post Sun Jan 29, 2012 9:15 pm
Nice1
I think it'll have to be much lower than the 2:93
the 2:93 coupled with the 328i box will only give a top end of 158,
and the 2:65 will give a top end of 175
Thats going off the info given in this link...
http://www.endtuning.com/gearratios.html
tyre size 225-40-17
(link stolen from jimbob ;)
dont know how accurate this thing is,
but i thought i would of seen more top end than 175 with the 2:65 diff fitted
craigieeb
Post Sun Jan 29, 2012 11:38 pm
Hang on, will the 6 speed box (E36 m3) bolt straight up to the M50?
Dezzy
Post Sun Jan 29, 2012 11:53 pm
craigieeb wrote:Hang on, will the 6 speed box (E36 m3) bolt straight up to the M50?
The S50B32 6 speed box will bolt straight on. It won't like the power you want to put through it though. :(
craigieeb
Post Sun Jan 29, 2012 11:57 pm
Is it a weak box? I thought it would of been quite strong.
Post Mon Jan 30, 2012 9:21 am
craigieeb wrote:Is it a weak box? I thought it would of been quite strong.
Nope, it is weaker than the 5 speed..
Good luck finding a 225/40/17 tyre..
215 or 235.. :wink:
Gunni
Post Mon Jan 30, 2012 10:07 pm
Any specific details of the 6speed being weak? I have not heard that before.
Gunni
Post Mon Jan 30, 2012 11:49 pm
I can't remember the specifics, unfortunately, but plenty get dropped for the ZF box in track cars or ones which are going to be abused.
Post Tue Jan 31, 2012 9:38 am
isn't it the synchros that go on the 6sp boxes?
Dezzy
Post Tue Jan 31, 2012 3:08 pm
Iirc it is something to do with the synchros, part un available to buy afaik.
Anyone know where recon S50B32 box's can be bought??
craigieeb
Post Thu Feb 02, 2012 4:12 pm
I'v been asking around about gearboxes,
and it does seem like the M3 box is more prone to, jumping out of gear, not going into gear, and just basically failing,
if I had got a box from the M3 and 100 miles down the road it goes "pop" I wouldn't be to happy, not only are they 5 times the price of the 328i box, there about 5 times the weight
so I'v opted to go for the 328i box
think it needs the seal changed :roll:
iv got the 328i manual prop and im getting a hold of the 2:65 slipper
(bit of a noob question..... what gear linkages should be used with that box? )
Post Thu Feb 02, 2012 4:18 pm
Think I used standard linkages..
I have a nice double shear shifter linkage from AKG if you are interested.. :) Replaces the single shear bottom arm.
Dezzy
Post Thu Feb 02, 2012 4:33 pm
Standard linkage is fine. Z3 lever in mine with new bush etc. works great.
craigieeb
Post Thu Feb 02, 2012 6:12 pm
Awesome i'll just keep the linkages thats on there and stick the "short shift" on,
thats on the car at the mo,
these flanges (no laughing at the back) landed today,
not much to look at but quite important at the same time :)
leeparkes
Post Thu Feb 02, 2012 7:32 pm
Nice flanges. :D
craigieeb
Post Fri Feb 03, 2012 2:36 am
Jhonno wrote: I have a nice double shear shifter linkage from AKG if you are interested.. :) Replaces the single shear bottom arm.
A one of these.....?
http://www.akgmotorsport.com/catalog/ca ... 20Shifters
A bit overkill for me
but if it's only a 10a :P
craigieeb
Post Wed Feb 08, 2012 7:50 pm
Dont you just love shopping in america
If only the ARP studs and the MLS gasket were that cheap,
A big :thumb: to the guys over the pond for sorting the invoice so I wouldnt have to pay a small fortune in customs fees :D
Woohooo time to crack on I reckon
ARP's to hold the sucka down
and a nice chunky gasket to get the compression just right 8)
ross2009
Post Fri Feb 10, 2012 10:18 pm
liking it muchly :cool:
Turbo M20
v8 project 6.0 twin turbo
craigieeb
Post Mon Feb 27, 2012 8:15 pm
ross2009 wrote:liking it muchly :cool:
Cheers dude,
I haven't been doing much lately due to family problems and also the car had a bit of a fight with a roundabout 8O
But now im back on the ball, :woohoo:
and looking for an intercooler...
I'v just been looking at your pictures Ross mate, and came across this...
what size is that mate? and do you know what it flows to?
is it anywhere near this...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 1917wt_981
