Kerrie's Touring M60 Manual swap
baptie0
well done, that looks amazing.
FormerMember
Great that you got it up'n'running!kerrie wrote:Took the car for the first drive today and it is a monster!! 3.73 LSD and it spins upto third, problem is that with the lightened flywheel the 3.0L clutch is slipping, so will need to remove the box and fit a 4.4L clutch, not looking forward to this!!!!![]()
The clutch slippage is not due to the flywheel, but due to the too weak clutch.... Training makes master, huh?
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
chips
- Was Pzero
Are you using a standard 3.0 clutch or do you have something a bit more special?
kerrie
Standard Clutch and a special flywheel! the flywheel needs machining to increase the pressure plate force.
M60 Touring and Sport
chips
- Was Pzero
I'm using the same bbb flywheel. Can you tell me some more about how it will be modified?kerrie wrote:Standard Clutch and a special flywheel! the flywheel needs machining to increase the pressure plate force.
kerrie
I am going to take a 1mm from the rim where the clutch bolts onto, it has dowel pins whch need to be removed and pressed back in, BBB said they will sort this for me if I return it, the new units should have this accounted for, when was yours made, My unit is a test unit fro BBB so not too bothered it is slightly wrong, teething issues.
- Homo Hair
JP exhausts in Cheshire?! You sent the car across the country for an exhaust?!
kerrie
Correct! they now have a M60 e30 template
- Homo Hair
Dedicated.. I went as far as Ashford.
si-
what sort of cash were the manifolds from JP??
Phill172
Standerd 3.0 clutch on a 4.0?
kerrie
Give JP a call they are top blokes, Yes a 3L clutch on a 4L!
chips
- Was Pzero
Do you know how much 'free space' there is between the flywheel and disc/disc and pressure plate when the clutch is disengaged? Is there a chance that it will not fully disengage?kerrie wrote:I am going to take a 1mm from the rim where the clutch bolts onto, it has dowel pins whch need to be removed and pressed back in, BBB said they will sort this for me if I return it, the new units should have this accounted for, when was yours made, My unit is a test unit fro BBB so not too bothered it is slightly wrong, teething issues.
kerrie
A small update, after moving house and having a baby, I have now been able to get the touring in the garage, I have removed the gearbox to replace the clutch and sort the slipping, also while I am conducting heart surgery I am wrapping the exhaust manifolds, painting engine mounts and fitting a 540i strut brace.
Will update when I have more info on the clutch issue.
kerrie
Hi Will, Yes that is a Gedore set, top quality tools!
I know how you feel with the autobox! don't let it put you off, Mine did the same and I found it to be a dirty selector track and a wire missing from the selector, I traced every wire on the manual and highlighted it once confirmed, you also need to remove the battery and ground the positive between fault finding to reset the fault code.
if you think it is quick in 3rd ( Limp) wait till she strats in 2nd and the drops to 1st, all kinds of hell breaks loose!
kingludba
Gedore chrome vanadium, I remember stealing the barlys no 13 and 10 for my bicycle, then getting clouted for not putting them back where I found them......
kerrie
Hi,
A small update, I have received my spec 3 clutch from the states, 3 weeks it took! but gave me time to wrap the manifolds and adapt a e34 strut brace, hopefully next weekend it will all be together, then just renew the MOT and I can use it.
toby
Good luck with the baby and the car's MOT sir! M20 Bedford Campervan sounds interesting too.
phi1
What strut brace have you used there?
Phill172
Looking really tidy in there!
Good luck with the mot.
Whats your spec on the clutch?
kerrie
Thanks, MOT passed no advisories, clutch is SPEC 3 from USA.
cruizin4dirty1s
could you tell me how you went about doing the hydo brake servo and have you got abs ?
einarsss
Is that clutch kit for e34 540 or?
I'm wondering wich clutch I can use with 5 speed and m62 LW flywheel (240mm clutch)
kerrie
The clutch is a 530i V8 spec 3, I used a M60 with 5 speed, 240mm.
