started rehousing pride and joy m52 into new p&g e30
slidey73
Post Sat Jan 30, 2010 7:49 pm
None vanos 2.5,24v,out/in,MY,e36,2.8i ,,,All went well today got both engine`s out with help from Mr,B a mate :) , Was not to bad had to jack up rear to make pulling them out sweet 8) tip from jimmymig , Sump swap oil pickup all there so quick clean pop them back on , Putting 2.8 in tommorow then all the fun really starts . i,v looked and been told about but i hate wires :mad: Well hope i`v took something in ,vanos where and :wtf: ews will not start with out it AAAA I see all wires so let`s get :banana: with it am sunday , I do get a bit :cheese: :cursin: when i get stuck :lol: will post my fun and games tommorow night
Post Sat Jan 30, 2010 7:52 pm
Nice one
If you want a plug n play engine loom sorting then speak with DanThe
Kos
Post Sat Jan 30, 2010 7:53 pm
slidey73
Post Sat Jan 30, 2010 7:55 pm
I`ll try first, told not to bad if get :x then i`ll try a plug and play 8)
slidey73
Post Sat Jan 30, 2010 7:59 pm
Kos wrote::?:
buy a com na ta e30 now :giggle:
Kos
Post Sat Jan 30, 2010 8:09 pm
slidey73 wrote:
Kos wrote::?:
in english please with less of the smilies :roll:
slidey73
Post Sat Jan 30, 2010 8:28 pm
Kos wrote:
slidey73 wrote:
Kos wrote::?:
dyslexia reading and writing = bad english and smilies coz i`m happy so cheer up or just no read( miz gut ) have a :flower:
MarkT
Post Sun Jan 31, 2010 7:02 pm
Coo, get some pics up mate. Where in swsindon are you? I'm from wantage :D
E30 340i project in progress now 328 turbo
Breaking '97 728i Auto box, tubular manifolds and other morsels.
For sale E34 M50 sump, pick up and dip stick. PM for de
slidey73
Post Sun Jan 31, 2010 7:23 pm
MarkT wrote:Coo, get some pics up mate. Where in swsindon are you? I'm from wantage :D
pic`s will be soon i hope groundwell end near A419 .
slidey73
Post Sun Jan 31, 2010 7:31 pm
Hello to all
I have 2.8l m52 engine swinging on a chain just above its new home e30 320 1988.
I need main engine harness connector diagram for the above cars so i can make a loom adaptor.
thanks :mad:
slidey73
Post Sun Jan 31, 2010 8:00 pm
willnz wrote:Also, please do not go posting multiple topics around the forum, keep it in one place. It only causes confusion. I have removed the other topic in tech help.
Ok Thanks
The colours are diferent on the e30 conector. Should I just match up the pin numbers and ignore the colours.
slidey73
Post Sun Jan 31, 2010 8:25 pm
Nice one, We could match 1 or 2 but that was all , Thanks will try and get it in tommorow ,
Post Sun Jan 31, 2010 9:26 pm
willnz's chart shows the E30 colours on the car side of the engine plug and socket, not those on the old engine loom.
Dave_M3
Post Sun Jan 31, 2010 10:06 pm
Best not to get hung up on the colours anyway and focus on getting the pins right as lots of people have different coloured wires and if you go by one of them it could mean you'll be short a working ECU :P
slidey73
Post Mon Feb 01, 2010 12:38 am
Thanks guy`s with this i`m sure to have her in and running soon if not tomorow big,,TA :D
Not so hard :wink:
slidey73
Post Tue Feb 02, 2010 7:16 pm
Hi
EWS FUN NOW
Transmitter module Pin 1 to Immobilizer module
Pin 2 to Switched Live
pin 3 to Earth
Electronic Immobilizer Module Pin 1 to 15 ?
Pin 4 to ECU on blk/vio
Pin 5 to Perm live
Pin 12 to ECU on black wire
Pin 13 to transmitter module
Just need to confirm the wiring for the above modules whats needed is the above correct ?
slidey73
Post Fri Feb 05, 2010 1:10 am
:clin: Gone a bit :banghead: :boom: How long to do a simple change :roll: got some help and now i`m abit , where`s this and that :?: put what where :?: time goes bye and not much get`s done , i,v learned now start to finish or dont touch my car :cry: :lol: hope to have some pic`s on soon with old P&G and new toy :D
slidey73
Post Fri Feb 05, 2010 6:04 pm
I NO THIS
slidey73
Post Sat Feb 06, 2010 5:22 pm
Hi
M52 2.8l has been dropped into an E30.
engine turns over - fuel pump primes but wont start. Fault codes show EWS and air intake temp.
injectors have voltage but no pulse.
Pics are coming soon.
Post Sat Feb 06, 2010 7:01 pm
slidey73
Post Sun Feb 07, 2010 1:31 am
Hello again iam using the key with chip still inside taped too the antena.No click heared .Fault codes for ews,air temp sensor and no pulse too injectors.thanks for all the help
slidey73
Post Sun Feb 07, 2010 3:37 pm
Hi
Same question as above EWS makes no clicking noise. how do i fault find this problem.
EWS has been fitted as per diagram on this site. i've checked all cables for contineuity.
Should it work alone or does it need data from ecu.
thanks in advance
slidey73
Post Mon Feb 08, 2010 1:44 pm
HELP STUCK ON DRIVE .Slowly giving up .. Now looking for another car .e30 dead . All done as told and no pulce to injetors . ews has got no click . Any one close to me that has done this before . or no someone that can help.............. e30 drive way in swindon................... :bmw:
slidey73
Post Tue Feb 09, 2010 12:41 am
..? siemens 5WK9 032 D13 .. ECU in 328I N.Reg not the bosh ecu, are all the wires the same? . All so look`s like it came from a 528i found this... http://www.megatec.gr/BMWfull.htm ... if you can help would be grate.. :mad:
slidey73
Post Tue Feb 09, 2010 1:53 am
gsxr750 spin`s up well & e30.328i new toy
Bob_S
Post Wed Feb 10, 2010 4:03 pm
ecu, ews box and key need to be from same car.
key might need wiggle to connect successfully to ring
if all done and not working, recheck ews wiring
Bollocks to this 24v scrap!
slidey73
Post Wed Feb 10, 2010 9:48 pm
:bmw: She`s running sweet as a nut
:cheers: too all no e30 site for your help you :rock:
I`m so happy i could :wan: but i`ll hold that back winkeye .
Will post pic`s of change when i can shrink there SIZE as only got dongo
NOW FOR THE BODY
:D BIG Thanks ,,
hope to see some of you this year at a meeting or two
