m50 info please
ross_jsy
Ah right.
Isn't one side meant to be hex shaped due to one being in tension and the other in compression? May be wrong mind...
No, its a myth, check the parts catalogue and you will see the mount was fitted in pairs and with a square mount depending on vehicle, the square mounts were also fitted in pairs on some cars
Baz666
if i brought everythnig to do the conversion is there anyone that will but it in to a car for me,
if so what sort of cost would that be.
The only reason i ask is that i might be going down a different route with the cars.
penton08
Baz666
it dont inclued auy of the m50 engine and stuff.
town325i
I hope your not planning on going to the dark side as in the M30's
- E30 Zone Meets/Events Team
Go for it Baz, over from the Darkside to the Good side
- Homo Hair
If he does, he is clearly a raving homo..town325i wrote:I hope your not planning on going to the dark side as in the M30's
town325i
Jhonno wrote:If he does, he is clearly a raving homo..town325i wrote:I hope your not planning on going to the dark side as in the M30's
Fook, you think too muchtown325i wrote:Jhonno wrote:If he does, he is clearly a raving homo..town325i wrote:I hope your not planning on going to the dark side as in the M30'sIf he does Rav will be bumming him a treat
town325i
Rav i have to do something while im not working
Baz666
No ladies i`m not going m30 i`m staying with the m50 Penton is talking about something completely different, in time i shell reveal all.
All can someone confirm i need the dipstick and tube from the e34 m50 ??
ross_jsy
Yes, and the sump.
Baz666
Nice 1 Ross thanks
Baz666
can someone help me with the part number for the oil pickup i need.
NO!!Baz666 wrote:can someone help me with the part number for the oil pickup i need.
Baz666
BITCH
Man that text you send me
Now i'm defo not helping you, SLAG!
Baz666
anyone know as i need to order asap
town325i
You need these part numbers 11411748150 11411703947 the first one is the pick up pipe and the second one is the gasket
Baz666
sorted dude ordered them today. thanks town
Baz666
I`v been told as my touring as abs i`v got to look for a air filter is there any other options other than some sort of k&n filter as i bloody hate them. but if i have to as anyone tryed the stealth air filters from Vogue Automotive ?? or should i just get a K&N.
http://www.e30zone.net/modules.php?name ... c&t=169127Baz666 wrote:I`v been told as my touring as abs i`v got to look for a air filter is there any other options other than some sort of k&n filter as i bloody hate them. but if i have to as anyone tryed the stealth air filters from Vogue Automotive ?? or should i just get a K&N.
Same as I have on mine.
Baz666
Thanks Brian so with abs i need the m30 box better start looking for one then.
Baz666
right can someone give me the info on ECU`s as i`v just been told i got the wrong one and need to know which one to get. sigal vanso none ews ecu ??? i think i need.
if anyone could give me the numbers of the ecu i know what to look for.
town325i
What numbers has your ecu got on it?
gcs325i
0 261 200 413 is the ecu you need, should have a red label.
Parts for sale - http://www.e30zone.net/modules.php?name ... 45#2733745
baptie0
shameless plug, I have a red label ecu if you are interested, pm me.
Baz666
Pm`ed you fella and replyed to you in the wanted section if it`s the number i need stated in the above thread then i have it.baptie0 wrote:shameless plug, I have a red label ecu if you are interested, pm me.
also if someone else can confirm that thats the number ecu i need then all`s good.
413 with a maroon label is the correct ECU for a M50B25 with vanos.
Label colour is important - a silver labelled 413 has EWS.
Baz666
Thanks again Guys, the silver labelled one was the one i had, i really thought it was going to be hard to find one top man baptie0
Baz666
Baz666
With my m50 all most done could someone tell me what would the best lcd diff to use something that would give me a better performance.
What box are you using Baz? If its an iS box then id opt for a 3.91 with an M50B25
Baz666
Thanks Dan got the link fella be in later, yeah i`m useing a iS box i`v got my sport diff but was going to look for another one for better performance.
