m50b25 vanos fuel but no spark
Remove the valves and clean both the valve stems and guides (blow them through with an airline, etc.), then try the valves in them again - if they slide up and down smoothly with no side play then the guides are probably OK.
Worn valve guides (or valve stem seals) may indeed cause some oil to drop down into the cylinders.
Possibly. Might be best to take it to a machine/engineering shop or decent garage and get them to inspect it...
yes im going to take it to a machine shop. And after that it should start but thanks for all the helpSpeedtouch wrote:Possibly. Might be best to take it to a machine/engineering shop or decent garage and get them to inspect it...
Today i got the head back from the machine shop and 5 valves was bend
But now that is fixed so the head is like brand new. And i think that it was the timing thats was off a little that caused it so im gonna correct it when i put it back togheter.
