engine was 100% good before i took it out from an e39.
noisy m52
Could be any number of things, exhaust manifold leaking, flywheel catching on sump, something not done up properly like engine mount, exhaust rubbing on something etc etc etc
lambda sensors done up tight?
- Contact:
Ticking and knocking are two very different noises.
How long had it been out of the 5 before you started again in the E30? My guess is a sticky lifter or two, common if the engine has been sat dry for a long time
well it's more like knocking,and yes it sat dry for about 12 monthsDanThe wrote:Ticking and knocking are two very different noises.
yes i did leave the plate...DanThe wrote:Not all E34 sumps have them though, only the 2 litres
If you left the pressed steel scraper plate on you wouldnt have been able to fit the sump with that baffle
