Rav's Chromie, Bodywork time
Post Tue Oct 23, 2012 6:10 pm
Cheers Mcbonio :cool:
Valves were vacum tested to test for any leakage.
Post Tue Oct 23, 2012 6:19 pm
Impressive work, but I hope that isn't a hairline crack in that valve seat, towards the top right:
Post Tue Oct 23, 2012 6:23 pm
I'll take a look tomorrow, but Byron did inspect it thoroughly before I got it back.
maggspower
Turbo Farmer Tractor Driver
Post Tue Oct 23, 2012 9:09 pm
Speedtouch wrote:Impressive work, but I hope that isn't a hairline crack in that valve seat, towards the top right:
No its a very small pube, they get everywhere dont they :D
Post Tue Oct 23, 2012 9:20 pm
You didn't go shoving your little willy into the holes Byron 8O
maggspower
Post Tue Oct 23, 2012 9:52 pm
Like I said give it a good wash :D
PMed
Post Tue Oct 23, 2012 10:19 pm
LOL, got it mate.
It'll be on it's way. :D
leeparkes
Post Tue Oct 23, 2012 11:44 pm
Nice. :cool:
Post Tue Oct 23, 2012 11:47 pm
More pics to come tomorrow Lee. winkeye
goosiegander
Zonegoose
Post Wed Oct 24, 2012 8:37 am
Post Wed Oct 24, 2012 9:59 pm
Why Thank You Goosie. :D
Post Wed Oct 24, 2012 10:06 pm
Nice to see you have somebody that knows what theyre doing on the case Rav :D
maggspower
Post Wed Oct 24, 2012 10:09 pm
DanThe wrote:Nice to see you have somebody that knows what theyre doing on the case Rav :D
Yes not bad for my first go :snigger:
Post Wed Oct 24, 2012 10:13 pm
This was your 3rd attempt! 8O
:hammer: :D
leeparkes
Post Thu Oct 25, 2012 10:32 pm
Where's these pics Rav?
Post Fri Oct 26, 2012 12:44 am
I'll update tomorrow, didn't get alot done today due to time. :?
zaust
Zone day release
Post Fri Oct 26, 2012 7:18 am
.6 - .8 Rav.
So you should be there if its all seated correctly now.
M30 Tech 1 Touring on gas.
Post Fri Oct 26, 2012 8:22 am
Cheers Marc, :D should be at the garage for about 11 today.
Will carry on building up the bottom end. :mad:
Post Fri Oct 26, 2012 9:27 pm
Only a small update to keep you happy. :D
Firstly, all new chain guides fitted yesterday,
New thrust bearing and shells fitted, dropped the crank in and tightened up the bolts.
For some reason, there was quite alot of end float which was a bit baffling, as everything was measured by using a micrometer :? .
So off came the crank again, the old thrust bearing installed, and then everything reinstalled again, this was to check the origional end float on the crank, cam to 0.005th :?
So, vice versa, new one installed, and for some reason, don't ask, there was reduced crank end float to about 0.002th, so checked and rechecked, phoned a few guys on the Zone to make sure and all is now ok. :D
jimbom30cab
Tech 1 freak
Post Sat Oct 27, 2012 7:58 am
nice one Rav, how did you get that crank shaft nut off - the mega tight one ??
Post Sat Oct 27, 2012 9:52 am
Loads of heat, and a 3/4 Snap On impact Gun, still took about 10 minutes though. 8O
That was lucky.
Nest time I will leave the flywheel on :mad: it'll help lock up the crank :D
jimbom30cab
Tech 1 freak
Post Sat Oct 27, 2012 4:06 pm
cheers mate. i've just picked up a B35 nice head and a shrick cam, so sending the whole lot off to Corry's to be re-furbed, i'll put some pics up when i get back. Still keep thinking about that B2B for sale on here but just can't justify the £££.
Post Sat Oct 27, 2012 5:07 pm
Seen it, looks a nice kit.
I'm thinking about it too :cry:
Post Mon Oct 29, 2012 5:56 pm
Had a little time to spare today, so got on with putting the pistons back in.
Oil'd up the bores, and put in all the pistons one by one.
The block was then turned over, new shells fitted and the rest fitted and torqued up as needed.
Decided to take the Oil pump apart and give it a clean before refitting. :D
And fitted.
Bristol_Jer
Post Mon Oct 29, 2012 6:46 pm
Nice work Rav :cool:
Post Mon Oct 29, 2012 7:03 pm
Bristol_Jer wrote:Nice work Rav :cool:
Cheers.
Have now decided not to fit the head on yet, needs to go away for more work winkeye
Bristol_Jer
Post Mon Oct 29, 2012 7:37 pm
Bigger valves? :D
Post Mon Oct 29, 2012 7:38 pm
Wait for it, wait for it winkeye
leeparkes
:squint:
Post Mon Oct 29, 2012 7:40 pm
leeparkes wrote::squint:
Lee, did you ever take the head of the Alpina??
mcbonio
Post Mon Oct 29, 2012 9:01 pm
Whats the final goal for this doink Rav? Turbo/supercharged?
Post Mon Oct 29, 2012 9:21 pm
When funds allow, ITB's and Supercharger. :D
leeparkes
Post Mon Oct 29, 2012 10:55 pm
No but ive been tempted to, Alpina valves are 1mm bigger also the chambers are Hemi style (but mahle pistons to match). This is why i mentioned Kos had a B10 bottom end with the M5 rods etc...
In your shoes id get it running N/A with the ITB's on to see what its like, then boost later when your bored with the power.
It will be plenty quick enough as it is with the mods you have done.
Tuned M30 FTW. :twisted:
Post Mon Oct 29, 2012 10:58 pm
Kos's bottom end winkeye was a thought when you mentioned it, but i'm on a budget :?
I'm going to run it on the ITB's first, to run the engine in for 500 miles or so, then it's getting boosted if I have funds, hopefully sooner than later.
I would like to see the Hemi chambers of the Alpina head though.
Any links you can think of Lee? :D
Post Mon Oct 29, 2012 11:00 pm
This is the next Head mod. :cool:
To match the head inlet ports to the Adaptors for the ITB's
