M30 install into calypso cab. Back on the road :)
Thu Nov 08, 2012 2:40 pm
That smallcase diff won't last 5 minutes!!!!
Gareth on here blew his, bent the whole casing :eek:
jimbom30cab
Tech 1 freak
Thu Nov 08, 2012 3:12 pm
flippin heck !! but not really suprised, i've not got round to researching the diff options yet....just taking my time doing the engine and then working backwards which is code for spreading the cost !!
Thu Nov 08, 2012 4:07 pm
What you need depends on how the car is to be used.
Everyday use, 3.46 or 3.64
Road and track use, 3.73 or 3.91
Bristol_Jer
Thu Nov 08, 2012 7:34 pm
I've got a 3.73 in mine, but it is a track car. With road tyres on I can do rolling burnouts pulling away in 2nd, don't need to bother with 1st :twisted:
mcbonio
Thu Nov 08, 2012 8:13 pm
I can't remember what mine is, 3.46 or 3.73. I have a usable 1st gear but I can also burn out in 2nd and spin wheels whilst moving in 3rd.! :twisted:
jimbom30cab
Tech 1 freak
Thu Nov 08, 2012 8:26 pm
bl**dy hell that sounds fun !! ok have to admit i'm feeling the need for a torquey cruiser in the cab so think i'll go with low ratio, 3.46 or lower, will keep my eyes peeled and do some swatting up on what will fit in the car as i've read there are small, med and large sizes.
Thu Nov 08, 2012 8:31 pm
Put a 3.64 in the cab.
I have a 3.46 but i do motorway mileage
jimbom30cab
Tech 1 freak
Thu Nov 08, 2012 8:42 pm
is the 3.64 a small case Rav?
Bristol_Jer
Thu Nov 08, 2012 8:45 pm
I wouldn't recommend a 3.73 for a road car personally, but it's perfect for what I want. Medium case is the one to go for, a 325 diff of some description
Thu Nov 08, 2012 8:53 pm
3.64 comes only on largecase.
Bristol_Jer
Thu Nov 08, 2012 8:59 pm
I had a medium 3.64 before my 3.73, I thought large case diffs were fitted to e28 535s and similar?
Thu Nov 08, 2012 9:04 pm
I meant medium
mcbonio
Thu Nov 08, 2012 10:03 pm
Its a lot of fun Jim, I've had mine running for 2-3 months now and the novelty still hasn't worn off.! I just can't help but thrash it. :twisted:
jimbom30cab
Tech 1 freak
Fri Nov 09, 2012 8:46 am
awsome !!! got any pics ?
jimbom30cab
Tech 1 freak
Sun Nov 18, 2012 8:30 am
Progress on the engine this week has mostly been cleaning old oil off the block, old gasket stuff and getting the block ready for painting. Shed loads of white spirit, scrubbing and wire brushing later its looking much better, although the garage looks trashed !! I'll get some pics up soon. I've cleaned up and bagged up all the components and just have the front timing chain cover to remove so i can get the chain, guides and stuff out. I'll get the oil pump and chain off today also. My garage is looking like an M30 parts store !!
jimbom30cab
Tech 1 freak
Mon Nov 19, 2012 8:32 pm
loads of scrubbing with white spirit and then wire brushing bought the block back to bare metal and then a coat of satin black hammerite. couple more coats and it should look good.
flywheel end which was literally coated in thick oil, none of this was visible at all. White spirit and an old toothbrush bought this up nice, new oil seals in order i think!!
leeparkes
Mon Nov 19, 2012 11:36 pm
jimboe39540i wrote: Spent ages looking at peoples M30 conversions mostly on here to see what the best looking colours are for the various bits. Lee - your's looks great so i'll probably do something very similar to yours if you don't mind!!!
Sound, The colour i used on mine was Hammerite aerosol hammered black, it comes out more a charcoal colour.
Goes on really nice with a suprisingly good finish, coming up to 4 years now and still looks good. :cool:
staley_turbo
Tue Nov 20, 2012 10:08 am
Id replace that rear crank seal while you can get at it. If it was covered in oil then it probably means its on its way out.
jimbom30cab
Tech 1 freak
Tue Nov 20, 2012 3:51 pm
i will staley_turbo, i've got one on order and have been swatting up in the Bentley manual :D
staley_turbo
Tue Nov 20, 2012 3:56 pm
Good good :D
I did mine after and its just a pain.
jimbom30cab
Tech 1 freak
Tue Nov 20, 2012 4:18 pm
yer i bet, big job.
Tue Nov 20, 2012 6:15 pm
I would replace every seal on that engine, i'm replacing everyone on mine as a precaution 8O
jimbom30cab
Tech 1 freak
Tue Nov 20, 2012 9:26 pm
Hi Rav, funny you should say that, the first batch of stuff arrived today in the post, well worth it i'm sure but not cheap!!! Recognise some bits here !!
Another order on the way from BMW then a load from Matt at ECP. Soon as i get my engine crane back from TPS i can get the lump in the boot of the trusty e39, i found a truck repair garage near work that can take off the cranknut for me, wip it off, take off the lower timing chain cover and send the boxes off for blasting and coating. Think i'll give the oil pump a good clean like you did also.
Tue Nov 20, 2012 9:32 pm
I ordered a complete Elring H/G set, and most of the seals were in there, and exhaust gaskets.
Taking the pump is not too difficult, should take you about 1hr to do. :D
jimbom30cab
Tech 1 freak
Sat Nov 24, 2012 8:53 pm
right, time to get this block sorted, took it round a local garage and they got the crank nut off pretty quick, i was well impressed, that windy drill did well.
also, this arrived from the stealers, xmas come early for me
so got the crank nut off and then took these bits down to the local blasters to get cleaned up and painted, all in about 20 bits, some silver and black and some just for cleaning up, they charged a ton which is not bad i think
so here chain end in stages
got those gasket faces cleaned up
oil pump to clean up next
really enjoying this stage
Sat Nov 24, 2012 8:55 pm
Did you not get new chain guides??? :?
jimbom30cab
Tech 1 freak
Sat Nov 24, 2012 8:58 pm
yer, both sides mate, did you see the big crack in the tensioner side in the above pics ? Had a good look at the chain and sprocket and they look fine, think i'll re-use them. Just thinking if i should replace the big end and main bearings now...or not ???
Sat Nov 24, 2012 9:07 pm
No, just looked at the goodie bags, seen them.
I would be replacing all the main bearings and big end bearings if you have it stripped down.
YOu won't find any in the UK apart from the main dealers, and they were quoting me £900 plus vat for those and piston rings.
If yu need some, you'll need to have the crank measured to see if it hasn't had a regrind.
Then PM Maggspower, I got mine thorugh him from America.
jimbom30cab
Tech 1 freak
Sat Nov 24, 2012 9:11 pm
thanks, flippin heck that is expensive, for now, i'll check for end float and if its in spec, i'll keep what i have, the lump is a low mileage decent one.
Sat Nov 24, 2012 9:12 pm
Endfloat is about 1-1.5th, or should be.
jimbom30cab
Tech 1 freak
Sat Nov 24, 2012 9:18 pm
thanks, i'll check and report back
jimbom30cab
Tech 1 freak
Sun Nov 25, 2012 3:03 pm
The sun was out this morning so took the old turd for a spin.
mcbonio
Sun Nov 25, 2012 3:34 pm
Looking good, love the colour.!
When you get the m30 in you might need to raise the front end you know, it's gonna get low.
sag
Sun Nov 25, 2012 3:47 pm
Rav335uk wrote:No, just looked at the goodie bags, seen them.
I got mine from the UK . It was around £160 all in for big and main bearings.
jimbom30cab
Tech 1 freak
Sun Nov 25, 2012 5:18 pm
where did you get them from sag ??
