Ant MAF Magic
petrol_1
Just been down to A TECH and had His MAF conversion on my 2.7.
Wow impressive!
The difference is big , compared to before !
(Even my wife noticed the extra Torque,) it will pull top gear from approx 1000/ 1200rpm ( on a 3.6 diff) and drives like its got lot more cc under the bonnet.
The spread of torque is really impressive and its a lot more responsive all round too )
No problems or down side only +++
All Ants R&D Time REALLY shows ( he's a true perfectionist ) and wont give up till its Right
Cold start is perfect (even today frozen icy one !) , pulls harder than before with instant throttle response ( not like the normal elastic std e30 one )
At motor way speed the MPG meter showing 40 / 50 at light throttle 70/80 So MPG will be better too
Also hes done me LPG specific chip too , Best of both worlds
A great job ,
Many thanks Dude [/b]
Wow impressive!
A great job ,
m_jermyn
Does this need to be done on a dyno or is it plug and play?
This is the next thing I do on my car
petrol_1
LIVE MAPPED , on mine ( but its on LPG and i had specific goals , which he achieved too )
but i beleive if you gave him the full spec whether std or tuned , i m sure he could sort you out , even in Sydney
My sequencial lpg ECU is now running more advance than std and afr of 17 / 18 :1 at idle so this is going to be so much better on fuel economy too , and we ve found that from a matched petrol to LPG fuel map this conversion is now needing approx 20 % less fuel at WOT when on LPG ,
BUT IS THE DRIVIBILTY THATS MOST IMPRESSED ME ,
Put this on your xmas list your E30 NEEDS THIS MOD
Speak to Ant a @ A TECH
Sounds great dude. Which engine is it?
petrol_1
Its a M20 ETA bottom end with 731 head
I ve got a std ETA ENGINE in an e30 too & this conversion is far more torquey than a std ETA and there built for T ,
Ajsingh
The standard eta bottom end... Did you change the big end bearings to stronger ones ie 325i ones or did you just keep the standard eta ones?
E30 Crazy!
petrol_1
Std ETA shells / bottom end
Just for remembed
I lighten the flywheel on this one , so the drivibilty is even more impressive than i first thought as it pulls so well
Just for remembed
e301988325i
Bookmarked, Ant what MAF are you using for the conversion? A siemens E36 one?
I said:
e30topless said:
lock the wife in there
DmcL
most likely.. that or a volvo one, think both are very similar, both are 4 pin anyway. actually been thinking of grabbing a 328i or M3 MAF just to see how similar and to try/compare both side by side as wel las swapping sensors/housings as i think the E36 housing is a little bigger than the volvo one. volvo one is perfectly sized to fit the standard TB elbow but its a little small for my liking, especially since i got that 64mm TB installed
WMMotorsports
chu346
So if this is a non standard engine type with an off the shelf chip, then after a live mapping session the car will be much nicer to drive.
I'm not too convinced on the maf conversion on a standard engine, but in this case where you needed a live remap anyway I'm sure it's worth it.
toby
I've driven one of Ant's MAF converted cars and the top end was particularly impressive.
scott180gtb
How much does the MAF conversion cost. I will need this for my 2.8 donk.
JazzMan
I'd be interest too for my 28scott180gtb wrote:How much does the MAF conversion cost. I will need this for my 2.8 donk.
TouringTash
Why not get in touch with the man fellas?
www.fastbimmer.co.uk has all the info you need. Email and phone number.
318i Touring
petrol_1
Give ANT a ring
Tel: 01959 534718 -
Email: ant.woodjetts@googlemail.com
hes alway busy so keep trying it will be worth it
AFM are RESTRICTING your motors Potential
Tel: 01959 534718 -
TouringTash
just email him as most of the time he's making far too much noise to hear a phone.
Or is that just when I'm there?
318i Touring
fowler
- Boost Junkie
jay its usually me making all the noise lol but yes chaps give him a call or alternatively drop him an email with all the car details and it will get responed too on mon or tues when i am down there.
EX A-Tech Workshop bitch !!!
gone but not forgotten
petrol_1
Ben
Is /when is atec moving ?
nearer to me last time i spoke
as i want to book the caddy in
fowler
- Boost Junkie
not sure yet mate best to give ant a bell or drop him a mail matey
cheers
Ben
cheers
Ben
