Door pull cables
rix313
Sun Oct 13, 2013 2:14 pm
Currently cungering up ideas for how to go about making a pull cable for the doors. Can any one show me what they've done?
Tah :)
Demlotcrew
Tue Oct 15, 2013 11:06 am
I used a cheapo dog lead off of eBay and just cut it to length.
You can just about see it in the top right of the photo.
Andrew
rix313
Fri Oct 18, 2013 6:35 pm
I guess I wasn't very clear I was after something to use to operate the door catch instead of the handle. Cheers though.
Demlotcrew
Fri Oct 18, 2013 6:41 pm
I just used the handle, its very very light!
Or you can use a piece of string, you only need to pull on it.
ross_jsy
Mon Oct 21, 2013 10:35 pm
I've got to ask what is the point? As Demlot says the standard door pulls aren't exactly heavy and your solution is just going to look messy and shit, not to mention encroach in the cabin more than the standard handle.
Mon Oct 21, 2013 10:47 pm
The only reason I can think of for doing this is because you want to move the handle forwards, for easier reach, otherwise I wouldnt bother
rix313
Tue Oct 22, 2013 8:59 am
ross_jsy wrote:I've got to ask what is the point? As Demlot says the standard door pulls aren't exactly heavy and your solution is just going to look messy and shit, not to mention encroach in the cabin more than the standard handle.
Its not an issue with weight. The inside of the door has been skinned so there is no where to mount the handle and the door cards are fairly thin, not sure how much they'd flex and I don't want to cut a hole in the to find it twists about.
Not sure what I'm planning would look shit otherwise I wouldn't plan on doing it.
Rallyprep_UK
formerly Driftnething
Sun Dec 08, 2013 7:28 pm
I used a seatbelt ! Will get a pic
Racing is living, everything else is just waiting...
http://www.rallyprep.co.uk
Phill172
Mon Dec 09, 2013 8:51 am
http://www.ebay.co.uk/itm/porsche-911-r ... 0992181053
These?
Andrew did you make your cards yourself?
Demlotcrew
Mon Dec 09, 2013 10:35 am
Sadly not Phil!
The cards came with the doors and are custom only fit made from Aramid for extra safety.
I recently bought a half decent vacuum pump and hope to be making lots of carbon parts in the near future.
First up will be some engine bay parts moving on to a sunroof panel.
Rallyprep_UK
Mon Dec 09, 2013 2:05 pm
A spare pair of E30 belt's recycled !
winkeye
