Quick release bumpers
ross_jsy
Post Tue Mar 02, 2010 12:40 pm
I have seen a few cars with bonnet pins holding the bumpers/body kit on. just wondering how people have done this and if anyone has pics of a tec2 kit like this it would be much appreciated
cheers,
ross
leeparkes
Post Thu Mar 04, 2010 11:00 pm
You can get e30 bumpers off fairly quick anyway if the bolts are just nipped up tight,
Undo two bolts and it will slide off, in under a minute i reckon.
MillRat
Post Thu Mar 04, 2010 11:09 pm
What, like this?
With 2 people, the splitter comes off in 1 minute, 2 minutes if doing by yourself..
Cheers,
Michael.
ross_jsy
Post Fri Mar 05, 2010 12:46 am
the bumper part isnt the problem, more the tech 2 bit
and thats exactly what i was after, cheers
MillRat
Post Fri Mar 05, 2010 1:27 am
If you do make something like this. We found it easiest to have the locating/supporting tabs on the side of the splitter which locate in the brackets on the side of the car (in front of the wheel). The front bumper also has a tab that locates into the same bracket on the car.
It will make your world a lot easier when putting the splitter on/off.
Cheers,
Michael.
ross_jsy
Post Fri Mar 05, 2010 10:16 am
i was thinking of using the stock side mount points as if im remembering correctly you just slide it on, may be wrong on that though
